BX snowblower and gravel
air1force1
2000 BX2200 2023 BX2680
Oct 30, 2021
Upstate NY
Hi, I have a BX2680 with a front mount snow blower. I have a long driveway with crushed gravel. At different times of the winter, when not frozen solid, the shoes would dig in tearing up the drive, and throw gravel in the yard.
I saw a good idea on you tube, to cover cutting edge with a 54" piece of black pipe. It worked really good, I could even go on the yard and keep paths open for my wife. This spring, noted the pipe was almost worn completely thru?
Has anyone came up with, or seen anything else.
Thanks
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
861
787
E.
I am not sure what your unit has for shoes but simply set the shoes to lift leading edge higher. If shoes have a very small bearing surface (or worse yet if the blower is a budget blower w/o shoes) there are tonnes of wide/large bearing surface shoes available to buy. If you are good with a welder and a little fab work easy t make shoes as well.
Me I simply back blade the first snow fall to make a frozen flat surface. My drive is very uneven and gravel. But here once the frost sets up the ground the snow stays for 4+ months frozen rock hard. YMMV
Bee-Positive
Nov 16, 2022
511
510
Amsterdam, NY
Schedule 80 PVC pipe is thicker than schedule 40 PVC pipe. Usually runs about $5/foot. I get a couple of years out of a piece I use on my SSQA plow blade depending on early and late freeze / thaws and amount of snow per season. I look at it as a disposable item that needs to be replaced when worn out.
Blue2Orange
Apr 3, 2025
260
159
Bayview Township
3pt mounted snowblower, but similar issues for awhile. First few snowfalls can be a pain when the gravel driveway is not frozen. Same in the Spring. Over the past +2 decades have thrown probably tons of gravel into the woods and ditch. For me it was the transitions going downhill from steep to flatter sections. Which then became more abrupt transitions with every winter. Until I got lazy.
Township doesn't have to clear our road until at least 6" of snowfall has accumulated or dropped. You need the proper vehicle with proper tires to get to your driveway. If the early season snowfall was light (less than 6") I would just drive the truck through the snow until packed. No more of a driving issue than making the 1 mile climb up the unplowed township road from the highway. Hopefullly packed hard by the time the blower is needed. Usually use the blade until the snowbanks cannot be bladed any further off the driveway. Until the surface is frozen hard blow with the edge angled upwards, skid shoes hovering above the surface. The 2-5" left until the surface is rock hard is just something I live with.
Might try the PVC pipe trick. New BX and blower. The shoes are more like side skid plates to protect the box edges from wearing. They are only a few inches wide and long. I can see them sinking into snow surface that is not ice hard. Or just do as I have.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,913
2,352
Near Lancaster, PA, USA
Unless otherwise noted, ''black pipe" means Sch40 steel pipe that is not galvanized to someone in the trades. If that's what the OP used I'm not sure what advice to give. If the OP used ABS or poly, maybe steel pipe would be better.
Bee-Positive
Nov 16, 2022
511
510
Amsterdam, NY
You're correct, black is steel.
I imagine it'd be a chore to cut/grind a slot the length of a black steel pipe and then try to fit it to the blower edge. Not impossible but...
Maybe there's other ways to mount steel pipe without cutting a slot.
PVC pipe cuts easily and has a spring like clamping action once pounded on. Some use various methods to hold it on. Mine slides on (with help from a "5 lb. assistant") and the blade lip is inside the pipe and keeps the pipe from coming off. YMMV. Just have to replace it every now and then.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
401
65
Wa
I have black iron pipe on my front mount snow blower.
I did try a single piece the length of the blower, but was unable to keep it straight or tight enough. I ended up just making it in sections.
I did use bolts to secure it, but I do not remember exactly how I did it. I would have to go out and look, but it has been in use a couple winters.
As for just adjusting the feet/shoes, if your driveway is crowned in the middle and/or the blower is wider than each side, then you usually pick up gravel until you make the driveway level with a base of snow/ice.
WI_Hedgehog
Apr 24, 2024
977
1,366
Milwaukee, Wisconsin, U.S.A.
Clamp the pipe to your workbench, then clamp a straight 2x4 (or rectangular aluminum tube from a boat lift) behind it as a guide. Ride the guard of the angle grinder along the guide, then release the clamps and slot the ends or cut them off. (If it's a wood bench and aggressive cutting wheel you might need to take a few light passes or cool it with water.)
An angle grinder, time, and a light touch often substitute for a machine shop when you live just right of the middle of nowhere.
