B2301 tipped over
modeck
B2301
Aug 28, 2024
Monson MA
My tractor went over a steep banking. After it was recovered the left brake is out of oil but the level shows full via dip stick. Also rear lift only works from 7 to 8. Any idea?
3,399
1,849
What do you mean by that statement? How would you know the LH brake is out of oil?
10,226
You lost me at left brake is out of oil??????
Look at all of the linkage for the three point, especially the feedback linkage.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
530
154
NZ
4,727
I know nothing about those braking systems, but I want the “tipping story”.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
277
226
Indiana
Me too - Let's see if AI can help...
It was a crisp autumn morning when I decided to tackle the overgrown field on my property with my trusty Kubota B2301 tractor. The air was filled with the scent of fallen leaves as I maneuvered the compact machine up the gentle slope, the engine humming steadily. But as I crested the hill, the ground gave way unexpectedly, sending the tractor tumbling over a steep banking into the ravine below. I managed to jump clear just in time, my heart pounding as I watched my prized possession roll to a stop amid the brush and mud, wheels spinning futilely in the air.
Hours later, with the help of a tow truck and a few neighbors, the Kubota was hauled back up the embankment and onto flat ground. Shaken but relieved, I inspected the damage. The exterior looked battered but intact, yet when I tested the brakes, the left one felt spongy and unresponsive. Puzzled, I checked the brake fluid reservoir—the dipstick showed it was full to the brim, but clearly, something was amiss, as if the oil had vanished into thin air without a trace.
As the sun dipped low, I fired up the engine again to assess the hydraulics. The rear lift arms responded sluggishly, only functioning properly between positions 7 and 8 on the control lever, refusing to budge beyond that range. Frustrated, I realized this mishap had turned a routine day into a mechanical mystery, and I'd need to dig deeper to get my tractor back in working order.
The next morning, I woke up with a knot in my stomach, determined to unravel the mystery of my battered Kubota. Coffee in hand, I headed to the barn and started with the brakes. Recalling some online forums I'd skimmed through late last night, I figured air might have gotten into the left brake line during the rollover—explaining the spongy feel despite the full dipstick reading on the transmission fluid reservoir, since that's what feeds the wet brakes. I grabbed my tools, jacked up the rear left wheel, and carefully bled the brake system, starting from the bleeder valve. Sure enough, a mix of air bubbles and fluid spurted out until it ran clear. After topping off the fluid just to be safe, I tested the pedal; it felt firm again, like nothing had happened.
Energized by that small victory, I turned my attention to the rear three-point hitch. The position control lever, marked from 0 to 10, was only responding between 7 and 8, which had me stumped at first. I inspected the external linkages as suggested in those same forum threads, and there it was—the feedback rod had a slight bend from the tumble, throwing off the hydraulic valve's sensing. With a bit of careful prying and a replacement rod I had from an old parts bin, I straightened and reinstalled it, making sure the connections were snug. A quick test showed the arms now lifting and lowering smoothly across the full range, no more stubborn glitches.
By midday, the tractor was purring like its old self, ready for the fields again. I took it for a cautious spin around the yard, brakes gripping evenly and the hitch performing flawlessly. That mishap taught me a hard lesson about checking slopes more carefully, but it also reminded me how resilient these machines are—and how a little DIY know-how can save a trip to the dealer. With harvest back on track, I parked it with a sigh of relief, grateful the only lasting damage was to my ego
Reactions: 6 users
xrocketengineer
Nov 14, 2020
887
868
Merritt Island, Florida
That was wonderful! The AI must have been there as a witness, it wouldn't make all of this up! 😁
4,760
DAYUM that story is even better them one of mine !!!!
BAP
Dec 31, 2012
3,097
1,234
Is it me, or does that tractor look wrong for a B2301. The roll bars and canopy look more like what is on a backhoe series and not sure what is on the front of the tractor.
Bee-Positive
Nov 16, 2022
580
614
Amsterdam, NY
@modeck glad you're OK and welcome to the forum.
Never mind these guy poking fun, they're usually fairly helpful.
Give us a little more detail so we can help you figure it out.
Hugo Habicht
G1900
Jun 24, 2024
1,253
1,800
Ireland
It's not you. Everything about that story is made up. (and I'm a bit suspect of the OP's first post too :unsure: )
Was that AS (*) generated too? :oops:
* AS = artificial stupidity. There is no such thing as artificial intelligence. This is only marketing manager and clueless journalists rubbish.
InTheWoods
Nov 17, 2023
277
226
Indiana
You may believe that, but AI is a thing and it's getting better fast.
(e.g. take a test drive in the latest Tesla, running the latest self-driving software and tell me AI isn't a thing)
Hugo Habicht
G1900
Jun 24, 2024
1,253
1,800
Ireland
No, it is not. Brain dead journalists call everything from digital image or sound processing or improved internet searches "AI" now. Not the slightest hint of intelligence in there. If computers would have intelligence (as in ability to learn themselves) they would have eradicated the humans a long time ago. q.e.d.
No, thank you, but you will never see me sitting in a Tesla (or any other Liion battery car). I designed Liion battery management systems myself and I know the dangers of this technology and the statistics of burnt out Teslas and cremated drivers. No reason to take extra risks getting killed prematurely (apart from the devastating environmental impact of battery cars on the planet).
And I drive myself, without all those, in my humble opinion, counter productive and dangerous "driver assistance" systems. I am not asleep at the wheel when driving and I will not have a computer deciding over my life in a critical situation.
InTheWoods
Nov 17, 2023
277
226
Indiana
Now that's the type of mind set I expect on an old tractor forum! You will be proven wrong in time, but I'm not wasting mine here with you.
