Adjusting Engine Speed on D1105
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
I recently purchased a D1105 to replace a blown up unit in an RTV I have. The only problem is that this one was from a Generator/Light plant. I am looking for information on how to adjust the fuel pump to get the new motor to rev similarly to the one that was in the RTV. The new motor is set up to idle at 1800 rpm, per the sticker, and I have read here that the RTVs are shooting for somewhere closer to 3000. Can anyone point me in the right direction? I am also doing research, but the info is scattered and confusing to me. Thanks for the help.
3,076
I believe that you will have to replace the governor in the new engine so it can go above the set 1800 RPM. There may be other things you need to change (injection pump, injectors,…?).
You may be able to swap them from the existing engine?
I know that the same questions have been asked before and answered so you might try to search for some information (if you haven’t already).
11,015
You will need to swap the complete governor assembly out and the springs.
You will need to compare the fuel cams, you might need to swap those.
There will be other adjustments to make once you swap all of that out.
You will need to set the timing on the gears when you swap the governor out.
Make sure you keep the injection pump shims with the block it came on as that set the injection timing.
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
Thank you both, I have been searching around here but nothing i find lines up exactly with what I am doing, I gotta believe its out there. Sounds like it's not as simple as just backing out a screw. This is my first foray into diesel injection pumps. One thing that worries me about swapping parts from the old unit is I suspect someone tried to turn it up to get some more speed from it and maybe caused the failure, the old one always was hard starting, smoked on startup, and seemed like it was revving too high to me. It had been turbocharged as well, but eventually it got to the point where it wouldn't hold a head gasket for more than about an hour. I am trying to go back to a slow and reliable machine that wont break again.
In my research it seems like I should do a spill test with the 1800rpm block to determine what shims to use when I change it to 3000 rpm. Do you really think the fuel cams could be different? Injectors(how would you tell)?
Thanks for the input.
11,015
You don't need to do a spill tests on the new one, the timing is the same regardless of the RPM's.
Just use the pump and shims on it.
Very unlikely the injectors or the injection pump is different.
You will need to follow the WSM on how to set up the fuel screws on the new model to match what the factory did to the old model.
Yes the fuel cams can be different (they all vary), it's not the fuel injection lobes that are different, it will be the way the governor attaches to the cam will be different.
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
Ok thank you, I am starting to gain some clarity here, I was thinking the lobes would be different and I was confused... I will start looking for a WSM for the RTV 1100.
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
I thought I saw a work shop manual page for the 1105 that had different timing based on the rpms you were going for. I know I saw it here on a page during my searching. I should have saved it. There were 3 ranges, 1800, 3000, and 3600 rpms and depending on what you were going for you adjusted the shims to get there. I remember the numbers were close, but not identical.
I purchased the manual for the RTV1100 and it just has the one setting on it, probably the 3000 rm one. The manual I have has no info on adjusting the speed control plate. Do u have any manual pages you could share on this? Thanks again.
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
This is the page I was talking about that has the different shim heights for RPMs
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
Well I pulled the speed adjuster plate off to have a look at the governor assemblies, looks like 1800 rpm motor has a pretty different setup in there. Most of the parts can be interchanged, it looks like, except for a threaded rod that is mounted in the block on the RTV 3000 rpm engine. The 1800 rpm engine doesn't have this, looks like a different casting even. My question is should I proceed with swapping the governor assemblies, or should I just try to open up the speed adjustment on the 1800 rpm motor. I purchased a work shop manual for the RTV, and the D1105 motor, but governor adjustments are not covered in them.... Thanks for any help. I have attached a couple photos of what I am looking at.
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
Looks like I have a BG series motor (from the gen set that has a 2 fork governor). The RTVs and other excavators and tractors have a "standard" series motor and are equip with a 3 arm governor. Anyone have any experience putting a 3 lever governor into a BG series block? Looks like it will all go in except for the "max torque limiter" which is the threaded rod in my last post.
Or does anyone know if the BG series blocks can be setup to run at 3000 rpm? I just need idle and full throttle really... I have attached some pages from the shop manual I am looking at. Any input would be really helpful. Thanks
ArcticOrange
RTV1100
Mar 27, 2025
Alaska
I am gonna post this here for anyone in the future because I hate when threads just die off and folks never get to the end of the issue.
I ended up using the 2 arm governor from the generator on the rtv1100 motor. I used a photo tach to adjust the max engine speed to 3000 rpm unloaded. I shimmed the fuel pump to adjust the fuel injection timing to 18 degrees.
Seems to run well and hasn't blown up yet.
