Root cutter
Chanceywd
Mar 26, 2021
731
675
central ny
So I had this idea to make a root cutter for when I am digging a stump or the tripping ones on the trails in my woods. I figured a hydraulic cylinder and some kind of weld up with a cutting edge.
Then I had a flash back to my vol fireman days and our Lucas tool.
So I thought maybe look them up to see how they are built.
Well I ran across this on ebay for $235 to my door so I bought it. About the price of a cylinder.
I flushed it out using the system on the 8n which I have filled with kubota fluid running into a jug both ways a couple times.
A couple hose adapters from Napa and spare hose and couplings I had and I took it for a test drive with a piece about 2-1/2" ash.
I think running it on the L2501 would work best if I could use a 12 volt remote of some sort to switch the 3rd function. it only needs to switch one way as the tool has a defined P port and a T port.
I tested it on the 8n using a string to my loader valve that is used for my power angle on the plow.
I think it might be one of my better ideas rather than loppers and axe method.
Bill
3,478
2,052
Bill
My first thought for trimming limbs was to mount something like that on the loader. For that price I would have jumped on it!
4,178
That thing is pretty cool looking. (y) (y)
Looks like a “jaws of life” set up to me.
Also looks heavy though.
Chanceywd
Mar 26, 2021
731
675
central ny
It is the Hurst jaws of life cutter. From late 70's or there about. It weighed in the 40's for shipping.
The fire department I was in had a different brand made by Lucas.
I am working on a method of using it with a hand truck so it is upright vertical and will cut the exposed roots on my dog walking trails.
Using the root ripper I made for my BH77 works on bigger stuff but makes a mess.. I may try to make a mount for the backhoe to just dangle and move around while standing on the ground. I ordered one of those wireless remotes so I can trip the third function which is the circuit I want to run it on. I already have that plumbed to my backhoe with 2 extra hoses for my thumb and push buttons
on the levers.
I also have a hook on the backhoe in the bucket linkage I can dangle it from with the bucket off.
Maybe a spring might work or just unhook. use then hood again to move.
Time will tell. Probably want to check my hydraulic pressure too.
Bill
jaxs
B1750HST
Jun 22, 2023
984
762
Aye-grannies I think you might be on to something. Having done some root trimming a couple times, here's what I found. Once cut the roots will sprout saplings which grow at an alarming rate. Heavy duty string trimmer will clip new growth if done soon enough and repeated often. From a practical standpoint mowing is better. Don't even think about herbicides, the tree will be killed.
Chanceywd
Mar 26, 2021
731
675
central ny
I have found what you say when I cut a maple sapling off close to the ground, it has a crown of those little suckers!
I do run a mower thru the trails but those cut saplings are to be avoided. That is part of my plan to cut loose or lower those somehow so no mower damage and not having to get the chainsaw into the dirt and dulling that.
I wish I could sprout seedlings like that on top of this 72yo bald head!
If it works as I hope it will be great, if not I figure I can sell it for what I will have in it.
I agree, no chemicals to be used here.
Bill
Hugo Habicht
G1900
Jun 24, 2024
913
1,289
Ireland
Why not attach it instead of the bucket? This way you could cut the roots by having the tractor doing the hard work.
Mighty cutter, by the way :love:
Chanceywd
Mar 26, 2021
731
675
central ny
Your idea is bouncing around in my head too!
The cutter has a built in spring loaded thumb operated valve which is designed to run with the source flow in one direction and continually bypasses the flow when that is in the center like any valve.
I want to see if I can just hold the operating valve say in the close cutter position and just reverse flow
from where I am feeding it from.
If that will work OK i could then mount it as you say and work from the backhoe seat.
If the valve was removed and just replaced with a plate and in and out fittings it would work remotely but it would make it so I couldn't use manually if a need was different.
Bill
Chanceywd
Mar 26, 2021
731
675
central ny
I tried my cutter out today for a while. I cut one that was almost 4" thru.
The pictured was was about 2-1/2. it works quite well but,
Before this I tried it with my 8N which I have a self installed front mount pump, tank and 2 spool valve.
I use this for snow plowing as it predates my buying the L2501.
The pump I used is rated up to 3600 psi and the Prince valve is rated for 3000 psi. but came set at 2000psi
I have been running it for about 9 years this way.
I was unable to find any real info on the Hurst cutter but see one reference to 5000psi.
I don't know if that was max or operating.
I just have been using a tarp strap to pull the handle back when using to test and then in the woods.
In testing with some 3" cherry limb pieces it wouldn't cut cleanly thru.
So I thought about and tried raising the pressure which with the prince valve is just remove a cap, loosen a lock nut and turn the set screw in 1-1/4 turns gave me about 2700psi.
That was a game changer, really cuts right thru now but I guess it won't work on the Kubota with it's pressure being less than that.
So not a complete success it will work with what I have in this 75 yo 8N.
I'm thinking about adding a third function valve to the 8N and using the wireless remote idea to turn it off and on. I am using about 8' hoses and ordered a pair of 10' today from surplus center to extend those so I can move around a little more. Now to make a better way to carry it and wind the hose when moving.
Bill
4,178
Bill
In my crowded head, I am conjuring some sort of “quick connect” for your BH77.
Even something as simple as dangling it from a chain attached to the bucket, and using the 77 to accurately place it, would probably be better than “hefting it” in place manually.
Just another example of “uses for a backhoe"... 😁
Chanceywd
Mar 26, 2021
731
675
central ny
The hydraulic pressure thing I think is going to keep me from running it on the kubota for now.
I bought shims for the kubota a while back but haven't tried changing. Maybe a slight boost in pressure on that would be enough I have checked the pressure on it and I think maybe it was over 2000 but need to put the gauge on the next time I start it up. I have a hook mounted on the bucket linkage so I can lift things with the backhoe and have the bucket out of the way for more height. I will look for a picture of that. I did it that way instead of welding a hook on the bucket and I have a quick attach already too.
I found it wasn't bad using in a loose method and with the cutter open the weight works in the vertical position to push down into the dirt both sides of a root, then close and cuts.
I have a set of homemade forks I have used to move pallets of wood for years on the 8N. I have about a 5' pole that attaches to the forks for lifting things with a winch. I was hanging it from that on a hook about head high between uses and moving. That needs a quick hook added about about waist high and the longer hoses. With that combo it should prove quite usable and could be handy to bring to a stump when I am digging out with the backhoe , 2 tractors better than one!
It is such an interesting tool , my brain is already thinking of ways to make detachable spreaders to go on the cutter linkage for possible use like that.
Bill
Edit
Here is the hook mount I made for the BH77 in the linkage. It is made from 2 pieces of 3/8 plate with the hook welded to one then 4, 3/8 bolts thru the open area and sandwich it tight.
It is before I put on the BX quick change not shown.
With the bucket dropped it allows me more room and lift capacity.
Chanceywd
Mar 26, 2021
731
675
central ny
It looks like I won't be able to run this on my Kubota L2501 because of lower pressure I am ending my thread here with this.
I have set up my 8N to run it and it works good at 2700 psi.
Thanks to Old Hokie for the 3rd function valve and base he listed on another thread for about $138 delivered. I bought that and a remote control maintained relay I got on ebay for $26, installed it and it works like I anticipated.
So since it isn't orange I'll end it.
Bill
