L 3901 won’t start. Help!
George1966
L3901
Sep 20, 2025
Megan wells
This 2017 L3901 has me in such a bind! It started blowing fuses when I would move the forward /reverse peddle. I have gone over and inspected every safety switch, connector wire everything on the whole tractor and can find no visual sign of shorts ect. I replaced the safety switch on the peddle. $140.00 later but still nothing! I am obviously not doing something right and seriously need help as I rely on this tractor for my living!
7,205
To find a short disconnect the wiring in the middle of the circuit. If the fuse still blows the short is on the battery side. If not its on the ground side.
Once you know which side its on repeat that divide and test process on the shorted side. Keep doing that until you find the exact location of the short.
3,056
Have you looked for mice and or rats chewing the wiring up? Sometimes them little sumbeaches can play havoc on the wiring.
5,515
2,226
look at the seat switch wiring too. Wiggle the wires around and look/feel for breaks, chafing, etc.
OttoOrange
L3560 with LA805 and BH92
Jun 12, 2019
15
Nova Scotia Canada
I am trying to test the plunger-style seat switch on a L3560 HST cab. I have removed it from the wire harness and I find about 80 ohms plunger UP and infinite ohms with plunger DOWN (closed). That doesn’t make any sense to me. Is the switch NFG?
I recently removed a large squirrel or mouse nest from the top of the engine near the muffler. I have also noticed my roll of shop towels in the cab have been chewed up and little bits of towel on the floor. I surely hope the little sumbeaches haven’t been playing havoc!
thx
