Fuel Storage (small containers)
sgerksinwi
L2501 DT
Aug 1, 2025
20
Wi
I'm considering using 4in1 Amsoil Diesel treatment in my L2501.
Located in S/C Wisconsin, so I thought with a of little use of the trackor this would be a all around thing to use.
My concern is the 5 gallon can of fuel that will be in the shed for more fuel if needed.
Treat that or treat it as I put it in the trackor?
This is Amsoil reply
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
68
Va
I’m in the same boat as you. I keep a 5 gal filled. I use very little fuel. I treat the 5 gallons too keep condensation out if it then I don’t worry about it. And keep the tank on the tractor full. I use Howells to treat my fuel
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Stanadyne in the silver bottle. 50ml per 6 gallons of fuel. I add the product to the empty can and the turbulence of the fill mixes it for me. Add fuel to tractor as necessary. No worries.
sgerksinwi
L2501 DT
Aug 1, 2025
20
Wi
Maybe the Amsoil product is the wrong choice for both.
Just wanted a simple solution for both.
jaxs
B1750HST
Jun 22, 2023
1,079
814
Understanding what can happen to diesel, why it happens and what to do about is more important than using most popular additive. While it's true taking measures to prevent water being introduced into diesel is prudent, the separator will catch it before reaching injection pump. Routinely checking separator for water and draining any that's present will usually prevent problems.
The main concern with water in seldom used equipment and stored diesel has to do with algae. Algae needs water to grow so no water, no algae. Monitor your source of fuel to see it doesn't contain algae. Watch fuel as it is being poured from storage container to tractor tank for signs of discoloration. If you notice discoloration, treat tractor tank and storage container with algae killer.
Buy fuel only from high volume stations,avoid hole in the wall and deep discount mom and pop places like the plague. That's where risk of getting algae is greatest. A more serious issue with these places is some mix waste oil and solvents with their diesel to boost profit. Operations are occasionally shut down where fluids collected from garages, transmission shops and such are sold for 50 cents per gallon to unscrupulous fuel vendors instead of paying $2 per gallon for EPA approved disposal.
One last word on water additives. DO NOT use same additives as used for gasoline. Those additives bind with water allowing it to pass through separator then damage injection pump and very possibly engine. Strange as it might sound, a bit of water decarbonizes a gas engine which improves performance.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
I'm in Wisconsin and keep bulk diesel in a dehumidified environment and use a water separation funnel when filling the tractor--which I try to keep full to keep air/moisture out.
Wisconsin is hot and humid, the temperature swings are what cause air to expand and contract and therefore move in/out of the tank daily, the cool nights causing condensation in the tank. Keeping the tank full means almost no air to expand/contact so very little most air is drawn in.
I put biocide and lubricant in a jerry can before filing with off-road diesel at the station (they filter water out quite well). In Winter I also use anti-gel in the cans so it's mixed well and start adding that to the tractor in late Fall.
I looked up comparitive lab testing on additives and picked the ones that made the most sense for my situation in Wisconsin.
