sway pin sheared off
netspyder
L3010HST
Jun 9, 2025
Missouri
one of these days, i'll learn to be more gentle with my machine. snapped one of the pins that holds the 3-point sway linkage - right at the rear frame where it connects. must've happened to the last owner of this, because the other side has a bolt with a nylock nut on it. anyone know what size pin this is? the kubota part is TA140-39820, but they never give you measurements or details of the parts. wish i would've thought to measure the hole - i could just do the same thing he did and buy a grade 8 bolt and a nylock nut.
7,195
From pictures at Messicks it appears to be a 1/2" x 3-1/2" (usable length) clevis pin.
4,184
^^^^ THIS ****
Do NOT use Grade 8 bolts in basic-frame attachments. A “pin” is SUPPOSED to Shear…. instead of expensive damage to major equipment and tractor-frames.
(and carefully reconsider / avoid using Grade 5)
IMO
netspyder
L3010HST
Jun 9, 2025
Missouri
@TheOldHokie thanks for that, maybe i'll get a pin instead of a bolt.
@GeoHorn fair point. it did bend the connector bits on the arm when it sheared off... my hope was with a bolt i might be able to straighten that out. maybe i'll just have to pull it and take it to a vise.
hodge
Nov 19, 2010
2,960
531
Love, VA
7/16" works fine, 12MM is the correct size.
netspyder
L3010HST
Jun 9, 2025
Missouri
@old and tired maybe, but i don't have a workspace set up to do that on a half in thick bar. now i have to decide if i order just that rod for $109 or the entire assembly on amazon for $94 from eparts
