Need chains for R4 industrial tires on a BX23S...
yorkies77
Kubota BX23S
Jun 7, 2020
79
62
Idaho
I got chains for both the back and front wheels on my BX23S. I used them once and haven't used them since. We get a lot of snow and have an uphill grade to our home. I have blown 1 and 1/2 feet of snow with no problems at all. Now watch, after saying that I will have problems this winter.
WI_Hedgehog
Apr 24, 2024
745
977
Milwaukee, Wisconsin, U.S.A.
Yeah I'm caught slackin'
Try:
(continued in Post #47)
Blue2Orange
Apr 3, 2025
159
80
Bayview Township
BX2380 with R4 and 2" spacer user. Consider chains over studs for winter use. Assuming the BX23s is similar design. If so, check out the driver's right inside the fender towards the front clearance. Attaching an image posted on another tread regarding chains. Space between the top of the tire and the shield plate is only an inch. Clearance everywhere else is fine.
Received an email from Buck at tirechain.com. Enquiry about best options due to minimal space. He noted the square link chain are 1/2" tall. Standard twist links 2 ladder chain would provide the most clearance. Thinking sort of a moot point if the chain is too loose. Will require routine checking of tension and definitely use chain tensioners.
Looked at the front wheels yesterday. The steering arm "knuckle" clearance is minimal. Like way too close to upper edge of the rim. I can see the side hook/loops of a chain hitting it with minimal loss or maybe even tight tension. Might just sip and stud the front for improved turning control and some traction improvement.
WI_Hedgehog
Apr 24, 2024
745
977
I keep the chains pulled to the outside and use three small rubber tensioners per side to keep them there.
Supposedly front chains aren't needed due to the weight of the implement, I might try going without this year on ice covered concrete and seeing how it goes.
Shawn T. W
Dec 9, 2024
319
583
SW Missouri Ozarks
One trick to "tight" chains is to deflate the tires, install chains, air back up ... Tight!
