David Copperfield, please meet Sherlock Holmes……………….
5,576
So a while ago I found this during a routine “suck and fill” style gear dope change…...
I basically buried my head in the sand, took my chances, and headed out west to whack some Prarie Dogs
Well for the life of me, I couldn’t think of what it was.
I mean there was a “little” (almost imperceptible) noise coming from some where, but this is a pretty big chunk of steel……and as the pictures raced through my mind, I could not figure out what it was/is.
Well the “Day of Reckoning” has arrived.
I pull the cover off and it’s immediately clear what has happened.
David Copperfield has made my “retaining bolt and retainer” disappear…….
It should look like this.
It is immedialty “crystal clear" that the chunk of steel on the magnet, was a part of that “anti-spin” clip.
But now that begs the question……”where the hell is the rest of it?” (Calling Sherlock Holmes…..Calling Sherlock Holmes…….)
So I commence to tearing it apart and find a few “clues” along the way.
First I notice this “gash” in the carrier…..
Then I notice another “gash"
Things are not looking good at this point.
So I inspect all the bearings and pull the carrier apart…..
The “aft pinion bearing” is pretty much “toast”.
The race is equally F’d up.
However,…..strangley enough the “forward pinion bearing” and the carrier bearing are relatively unscathed.
I might even venture to say that all the other bearing could be “re-used”, but I am neck deep in this and the bearings are all already bought, so…….They are going to get replaced.
5,576
Well I put my "Sherlock Holmes Hat” on and here is my theory/guess/deduction.
I think that the retaining bolt, after about 1/4 of a million miles, just “fell out”. (for some unknown reason)
This caused that retaing clip and bolt to get between the carrier and the “pig” causing the “gash’s”.
Eventually that combo of steel parts was “flung” into the opening at the top of the following picture…..(That opening feeds oil to the aft pinion bearing.)
The pinion bearing then began to “grind/crush/eat" the bolt (and retainer), eventually grinding them to “dust”.
This seems the most probable explanation in my head. But I am open to other theories….
Well now I begin to remove the other bearings with my new “bearing removal” tool.
Then begin to press in all the races.
Just by “coincidence” some of the “bearing tools” that I made for the rear diff, are fitting the front.
like below
I do have to resort to making one press tool, but that was it.
I remember hating this style of bearing seal, and it’s giving me a bit of a “tough time'
But I eventually get both of them in.
For whatever reason, this new seal keeps popping off that spring……I tried it a number of times, but in the end I had to run to the store and just decided to replace it, even though it's “new"
Now it's just a matter of properly “torquing’ that damn crush sleeve.
This “torque multiplier” has come in very handy, and makes crushing those sleeves, very easy.
I got that “pinion turning torque” and the “backlash” set to “dead nuts” perfect.
so its time to reassemble her.
So as I pick up the starboard axle shaft/hub assembly….I feel a “clicking”……Hmmmm??????
I could have sworn I just replaced this side not too long ago…….But I’ll be damned…….
Apparently one of the cups was not getting grease…M______________R!!!!!!!
That bitch was toast…….So another 100 dollars, and a day later, my new “greaseless Spicer U-joint” show up…..
ATTENTION!!!!!!! For those who have never “read" the Spicer Greaseless packaging (like I didn’t the first time I used one) You MUST keep the caps in the order they came.
HEY SPICER…..Thanks for putting those directions in BOLD, BRIGHT letters for the guys that don’t read the directions, becasue they have been replacing U-joints since Jesus was a Corporal……a$$holes……..
Now I have one that was put on keeping them in order, and one that I f’d up and mixed them, so I guess we will see the difference in “life” between them.
here it is “all dressed up, but nowhere to go"
The End!
Reactions: 7 users
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Well done my friend..... Glad you were able to get the ole girl all fixed up!
11,276
I'm going to say the more likely option is someone has been in that axle and put the retainer wire in place and simply forgot to put the bolt on it. ;)
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
High pinion Dana 30s are good to have. But the bolt and clip I never remember seeing.
I hope that you put in a Detroit locker or True Trac since the carrier was toast.
Might as well put on a big lift, regear the diffs and roll on 37s.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
It's very simple where this bolt went.
It has been chewed up.
Plenty teeth in there...
5,576
If so, then they snuck into my garage at night and did that, cause I drove it "off the lot” when it was brand spanking new, and haven’t touched that axle since...;):)
5,576
I can never keep up with what years they put what axles in, but this year they were using AAM 9.25’s.
Been rolling those 310’s since the day after I brought it home. (Although I did recently switch from Goodrich to Kenda’s….which have been a faboulus tire BTW)(y)
xrocketengineer
Nov 14, 2020
918
882
Merritt Island, Florida
Good Job! This reminds me of when my Mini broke its differential. It was probably because I have the high output engine (65HP :ROFLMAO:) or because the spider gear pin "was made out of chocolate" like some people say of that vintage Mini.
I had to get a rebuilt gearbox from the UK from the top expert, Guess-Works.:eek: The owner is John Guess.
4,248
I doubt the bolt & clip were chewed to dust. That was a Friday or Monday diffy and the bolt was never installed.
Noise made by that diff’ would have likely been on acceleration…. due to the rear pinion bearing going-out. That ring gear is so beefy, it might have gone another qtr-million miles without trouble, except for the pinion bearing.
It’s a mystery for that gash made in the carrier… Did you find anything on the case-walls that appeared to be gashed like that? I have a difficult time imagining there’s anything else nearby to have “jammed” the clip (or bolt if it were ever present) against to cause that kind of disruption, and the manner of movement during operation does not lend itself to a “gash” shaped in that manner or direction.
All these ramblings of mine are purely my own imagination…. Nothing to rely upon experience-wise. (Although I was the only factory-trained rear-axle/differential technician at Palm Center Toyota of Houston in early 70’s)
I have seen worse damage that made no noise whatsoever.
BTW, that little ”tunnedl” above the ring-gear going fwd allows the ring-gear to sling oil fwd to distribute onto the pinion and is how the fwd pinion bearing gets all it’s lube. (but you knew that… comment made for anyone never seeing inside one of these.)
I agree that Your Posts are some of the Most Interesting seen anywhere on the ‘net. Thanks!
