Ripper type tooth for my Backhoe scoop
Paul Rae
BX24D and BX25D
Does anyone know of a ripper type tooth I can connect to my BX25D backhoe scoop.
I would prefer that it clamps onto the scoop so It is quick to install and remove.
I have several stumps I need to remove.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
I don't think a clamp on will stay put once you start putting the power to it ...
https://www.bxpanded.com/bx25d makes a "Quick-On" which it's a matter of seconds to swap out stuff on the end ... They make a ripper tooth too ...
5,358
I don't think a clamp on will stay out once you start putting the power to it ...
Thats the system I have for my 77, and it works great.
The only “thing” is the “quick discount pin” kept falling/getting bumped out, so I went with a bolt and Ny-lock style nut.
It is a little annoying to have to use a wrench, but it sure beats looking for that pin when it falls out.
Even with that “flaw”, I would still recommend it.
I have pulled many stumps with mine. Some of them were “pretty good size” too.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
I've only "lost" my pin once, and that was using the 6" trenching bucket in rocky ground ...
For those that don't know ... How it works is you hang the red pin in the slot, and then pivot the purple hole up and put in the pin, and fasten with the clip, that I "lost" in the first picture ...
If you click on the link in post #2 and look at the pictures, there is a video in there that shows it being done ...
I am EXTREMELY Happy with this system, it truly turns my TLB SCUT into a Swiss Army Knife Tractor with all kinds of extra capabilities!
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
198
271
Hardy, VA
My weekend adventures in land clearing - mostly 6-12in trees - for a road expansion with my OEM bucket made me start thinking about a better solution. I need to rip out roots and pull out the stump all while not leaving a huge hole and piles of dirt that I then have to sculpt back into firm ground.
Lo and behold... I find that - as usual - the interweb was way ahead of me. Bxpanded makes exactly what I had envisioned and at a cost that is reasonable when I consider the time and effort plus material costs to fab something of my own.
This group is a great resource for getting great feedback from people who already own and are using the product. I am basically sold on it now.
Does anyone know if BXpanded offers a OTT discount?
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
I'm not aware of any discounts, but I can say that they build top quality products which will probably last you a lifetime!
I also got there 2" receiver hitch, never really used it at all, the other day I was stringing out another strand of barb wire ... So I put it on for the first time ...
BH's are handy! :cool:
A couple of wraps around the pin, and it's ready to tighten, just don't over do it!
Once you get the Quick-On, you'll find it's simple to switch out to what you want, kinda like opening up a Swiss Army Knife picking what you want!
This was my first stump, and I did kinda make a mess ...
But it's easy to clean up!
trikepilot
Jul 18, 2020
198
271
Hardy, VA
Yeah. I eventually figured that out and went ahead and ordered the ripper and the quick on. Not sure what their lead times are like these days but I am excited to get the new toys in. I have watched a few vids today on the install process and the ease at which you can swap BH attachments. Ill only have the OEM bucket and the ripper to swap between.
I thought for a half second about the trailer mover but decided it would get no use. I have a RTV and a 3pt trailer hitch attachment that moves all my trailers with ease.
Shawn T. W
Dec 9, 2024
793
1,430
SW Missouri Ozarks
It had been sitting on my shelf for over a year, I have a hitch on my bucket ... I originally bought it thinking I could make a "spike" out of angle iron to push/wiggle into the ground when it was damp to kinda make a slot to plant T-posts in, to save my poor carpal tunnel wrists from the manual driver ... But never got around to it making the spike ... I now have the L5030, so am considering getting a real post pounder to put on the back of that!
Lencho
B7100hst
Jan 21, 2017
451
121
NM
Hi Paul Rae, I also recommend the BX Expanded ripper tooth. I don’t have the quick attach but it’s only 2 pins to swap out my bucket. $300 well spent. IMG_0716.jpeg
trikepilot
Jul 18, 2020
198
271
Hardy, VA
A quick update in case others find this thread like I did in a search for info on a backhoe root ripper.
I ordered my ripper and quick-on 3/3 and it arrived 3/23. Install was straightforward and easy - maybe 20mins.
20260403_175940.jpg 20260403_175929.jpg 20260403_175924.jpg 20260403_175319.jpg 20260403_175309.jpg 20260403_175305.jpg
trikepilot
Jul 18, 2020
198
271
Hardy, VA
I got out there early this morning and started using it and in a couple hours I had removed 20-30 trees and stumps varying from 4in to almost a foot in diameter.
This is a great little tool that quickly tears thru tree roots so that you can push over the tree and its root ball. I do think I'd like the ripper shank to be longer but maybe they designed it that way to reduce forces on the backhoe linkage.
Regardless.... it made quick work of the tree clearing for my road and did not leave huge craters where the trees had been so cleanup with the front bucket and box blade was easy.
