The RC72-29A driveshaft clocking mystery
jbeech
Kubota L3010, Jacobsen 417D
May 23, 2025
39
19
Sanford, FL
So I bought a used 30hp tractor last year in large part because it came with a mid-mount mower deck. This, in addition to a 5' brush hog. Anyway, what I especially wanted (my hot button) was the mid-mount belly mower.
By the way, in this photo, the mower deck is merely held in place with sweet wire, it isn't actually installed. I didn't know this when I had it transported from 200 miles away (not that it would have mattered because this is what I wanted and it was slim pickings when it came to finding a mower with mid-mount mower deck).
So the reason I wanted the belly mount is because I hoped it meant going from a zero-turn with 17hp to 30hp with the added benefit of it being a 6' wide vs 5' for the mower deck on my zero turn. However, it's the added horsepower, which is what I suspect will let me get the job done more quickly (horsepower more so than the extra width).
So in all honesty, my only interest in the brush hog was being able to mow when I've let the grass get out of control, e.g. knock it back. If this happened before I bought the L3010, I had to pay a fellow to come knock it down with his brush hog. But in truth, I try pretty hard not to let the grass get ahead of me.
Unfortunately, the brush hog crapped out the second time I went to use it (the gearbox went south and gear oil everywhere as the case cracked - catastrophic failure). I figure it was just one of those things because it worked fine the first time I mowed with it.
Anyway, I ordered a 5' flail mower to replace it because these stick out behind the tractor considerably less than a brush hog does. That business of sticking out is a pain in the arse in my opinion (especially when working close quarters, e.g. surrounds). Means having to pay more attention whilst working (this for 5 Florida acres I've been maintaining for 20+ years with the zero turn).
Anyway, and as it turned out, while the belly mower was included, this didn't mean he'd been using it. There's a difference and in point of fact, not only did he gloss over the fact he never actually used it, I was insufficiently savvy to ask (classic reason we learn not to assume). And no, not angry despite some required bits and bobs for mounting/functioning being MIA (this, because I suspect the seller himself, a nice guy, didn't know).
Note; Kubota is pretty good but their magic does not include still selling spares 20+ years after manufacture (meaning some parts are unobtanium). Meant resorting to fabrication: RC-72A missing link; a-brief-how-to before trying the installation.
Further delaying the belly mower being put into use (beyond my general unfamiliarity with the tool plus the usual excuses, e.g. work-life balance) is that I still have access to the zero turn. Means the pressure is off to finish the job because I have with what to mow. Anyway, by now several months have gone by - yikes - tempus fugit!
Added to which, mounting and adjusting is complicated by issues to do with me. Basically, I'm an old fat ass rather disinclined to work beneath it.
Since i have a two-post lift for working on cars, I'm still tryign to suss out a method of using it with the tractor because I really hate laying under it.
So with the background established, now to address what is hopefully the last complication . . . I can't seemingly clock the driveshaft correctly (so the two U-joints are in proper phase). Let me explain. Recapping; single shaft drives - in my experience - are clocked flat. This means the two U-joint are in perfect phase with each other if you lay them shaft flat on a workbench.
Problem is, the shaft won't clock properly. I can only get the two splined shafts to mate whilst perhaps one or two splines out of alignment, maybe 10° out of phase. Why? Dunno but I tried every single spline and it would only go together the one way so maybe it's made that way. Regardless, color me befuddled . . . and yes, it's hard to tell but in person it's clearly not phased correctly. Made this way by mistake? Dunno, and don't see why this would be.
Anyway, largely because I've been otherwise entertained with getting the mower deck properly mounted and adjusted, I'm only now circling back to this driveshaft alignment business. In other words, I haven't yet engaged the mid-PTO so I don't know how much it'll vibrate this way. Maybe it's inconsequential, dunno. Not going to try it and thus, I fear the deck is coming back off once again (pain in the hind end, believe me). This, so I may attend to the clocking - UNLESS - some kind RC-72A owner looks at theirs and goes, wait a minute, John, mine isn't clocked 0°-0° either!
Absent this, then the shaft comes off and goes to a driveshaft specialist because this thing is also unobtanium from Kubota dealers and I'm not running it this way absent more information. In fact, push come to shove (it shouldn't) , I'll have them make me a new one. After all, new two-piece shafts are cheap enough - this one on Amazon for <$100, for example - and as long as we cut the U-joints off and re-weld them properly to the new shaft, then mower deck itself will never know the driveshaft is not Kubota OEM as long as it slides in and out to accommodate the difference in length as it's raised and lowered whilst traversing terrain.
Any RC-72A owners willing to take a careful look at shaft clocking for me?
9,287
I think you might be overthinking the clocking of the drive shaft.
Have you tried flipping it 180 degrees on one end?
FYI: Your mower deck should be RC72-29A
jbeech
May 23, 2025
39
19
Sanford, FL
Yes, of course, RC72-29A, corrected the title. And no, not overthinking, darn thing only goes together on way!
9,287
No, i mean overthinking, in that being off that much will not hurt it's operation. ;) :ROFLMAO:
3,654
The DriveShaft is clearly Not out-of-Phase …. but your mower might need to be rotated a few degrees….if I’m understanding your post.
You Do Not want to cut the u-joints off and re-weld them in a different position. You either need to rotate your tractor pto OR the mower-input shaft.
WI_Hedgehog
Apr 24, 2024
844
1,167
Milwaukee, Wisconsin, U.S.A.
NOTE: I'm not a tractor expert, I'm an automotive guy, and not an expert in that either.
I understand +/-3 degrees is acceptable on low-speed applications, though there's more to the story as use-case can make all the difference.
Sometimes the clocking is done to eliminate speed variation due to unequal input and output angles, which could be the case on your mower deck given the rather large tractor size.
It could also be the wrong driveshaft.
This video explains phasing and speed variance in relation to equal and unequal angles:
jbeech
May 23, 2025
39
19
Sanford, FL
Great video, thanks for sharing! I'll be crawling beneath that rascal later today as some new clevis pins, which I ordered, have arrived. Dread doing this. Anybody devise a good way to raise a tractor using a 2-post lift?
MOOTS
MX6000
Jun 27, 2019
2,188
2,713
Canton, Georgia
FTG figured it out. May not work for you since the deck is on the tractor. I have a turf kit on my lift at work in that thread.
jbeech
May 23, 2025
39
19
Sanford, FL
Thanks for sharing!
And yes, I agree with you, the belly mower makes that method impractical.
That said, strikes me folks with tractors are some of the most ingenious ever. Thinking someone may yet come up with an idea. Never know if I don't ask!
