Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
Tried to add photos to my post yesterday regarding the yard hydrant project but wouldn't let me add images. Despite the rocky soil, the BX23S really was fantastic. I think I paid for the backhoe doing this project myself. With the hydrants (decided to go with Merrill hydrants, made in the USA so they were almost three times as much as the cheap hydrants at Home Depot), PEX, fittings and crimp rings, PEX tool, PVC couplers and pipe, piece of sewer line, shielded couplers, wire (for tracer line) and gravel I was in at around $1,200. Can't imagine what it would cost to hire someone to come in and dig the trench and hire a plumber to install everything. Would have definitely been much faster, but I saved a lot of money doing myself and wasn't in a hurry and learned a lot. One hydrant is where I'm goring to put a greenhouse and garden beds, next one is where the burn pile is and third one is where the chicken coop will be. There's fourth one I installed a few moths ago but all I needed to do was replace a faucet coming out of the ground with a freeze-prooof hydrant since it was already about 32 inches deep, and then tapped into thatlinefor these three new hydrants. Used PEX since I already had it. Worked outsell and made the install go super fast, and was especially convenient when I has to re-routhe the tech around boulders in the ground.
Trench ended up being just over 200 ft long and three feet deep (frost line here is 2 feet). Dug down an extra foot under each hydrant to accommodate a bed of washed pea gravel for weep hole drainage. This was where I originally started, but ended up taking the starting point about 30 more feet back. Trench goes up this slope and wraps around to the right between the carport and house.
Weep hole taped during construction to prevent debris from getting into it. Used quarter-minus gravel to bury the line. The soil here is VERY rocky and wanted to enclose the line in the quarter-minus for protection.
It's hard to see in this photo, but couldn't get tractor access to the other side because of trees, so I just drove yup the berm when I was filling in the trench with the gravel.
Here's where I had two trenches meet and then continued where I tapped into an existing outside water line.
As previously mentioned, trench is three feet deep, except at each hydrant where it's 4 feet deep. Did this to accommodate a bed or washed pea gravel under each hydrant, then placed a 5 gallon bucket with the bottom cut out around each hydrant and also filled that whitewashed pea gravel. Used washed pea gravel to prevent any dust or dirt from clogging up the weep holes. Probably not necessary, but was easy to do. Using t-posts to mount the hydrants was also nice since it allowed me to use hose clamps to get the hydrants in place and set their height very easily. and get them standing perfectly perpendicular. Also provides a bit of stability once it's all filled in.
This is where I accidentally hit a sewer line that wasn't supposed to be there. Turned out to be an RV clean out that I had no idea was there. Repaired it and re-routed the existing outside PVC waterline and connected the PEX to it for the additional three new hydrants. Probably didn't need to use such heavy duty 4-band shielded couplers, but it's super sturdy now and isn't going anywhere. That RV clean out goes up to the car port. That's great because I hope to put a shop where the carport is some day, and the clean out means I can easily install a sink and toilet in the shop.
Reactions: 17 users
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
438
694
NH
Big project. Nicely done. I am envious of your frost line depth.
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
Ste Geneveive county, MO
Had a busy morning yesterday. I took the 3pt arms off the L3901DT and connected the BH77 to the tractor. Dug out a stump in the front yard. Then took the BH77 off the tractor and reinstalled the 3pt arms.
I do have a dolly that I made for the BH77 and it make connecting and removing the back-hoe a LOT easier.
Reactions: 13 users
The dutch guy
Kubota new Sunshine L1-225 with a Cochet FEL, flailmower, Tiller, chainharrow.
Jun 4, 2025
The Netherlands
I have been busy with mowing and tilling the garden.
this weekend we got about 400 tons of dirt delivered. We removed a large slurrytank about 1,5 years ago and still had to fill the hole in left.
now that this is (nearly) done, it is time for a big garden make over.
next job is leveling out the garden and sow grass. The tilling took more time than planned, so i had to use my worklights. Turned one to the back and kept one pointing forward. It worked for now. But i will add an extra light in the near future. FA6F9B47-A108-4955-BE25-F99B20D55E58.jpeg IMG_6848.jpeg IMG_6854.jpeg 4a889b17-9c09-4ea0-8729-75364feb84f6.jpeg IMG_6859.jpeg
Reactions: 14 users
BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Mar 20, 2016
95
188
Evansville, IN, USA
Care to attach a pic of your home-made dolly? That's on my list. I don't have a Kubota BH. Mines a Taylor-Way (Italian made). I been sitting it on a wood pallet out back of the garage, but I'd like to get it on wheels inside the garage ... one of these years :unsure:
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
Put the backhoe back on this morning. Takes more effort removing the quick hitch and three point hitch that it does removing and installing the backhoe! Can't believe how easy it is to detach the backhoe.
gbaker53
Kubota B2401DT&FEL RockRake, Rear Blade, Cultipacker, SeedRake, Driveway drag,
Mar 28, 2025
153
115
NC
What I did on my kubota 5 years ago:
Y'all ever had to do anything silly like this?
Just before we fully relocated out here, i'm running home real quick to get the garbage to the curb. Took my little yota, thought i could make it, immediately got her stuck at the bottom of the hill. She's lowered on toyo proxes....had to get creative LOL!
100ft extension cord wrapped around the box blade..... pulled her all the way back up to the road LOL!
I noticed your tag in Mississippi! My wife and I have been looking at possibly moving out of NC. I have lived in the south a good part of my life except 32 years in Missouri. Even as a Marine I was stationed in the south most of my career. Want to be in the south because I hate snow. Anyway my question is, is land prices per acre there reasonable for 5 to 10 acres? Here the land is ridiculously expensive, mostly 10k per acre. Just looking for a nice property with a creek or stream and mostly woodlands. Just want to build a small house 1000 SF or less. Possibly a barndominum style house. So NO restrictions since we will live in the camper for a while. I don’t need to have the ocean or lake just a nice creek or stream to look out to or sit by as life expectancy is hopefully into my 90s, both parents are 97. Give me your opinion of Mississippi life!
mdhughes
L3901DT
Dec 10, 2014
1,449
1,478
This is the only picture I could find of the dolly. It is made of woods and two fixed wheel and two swivel wheels. The fixed wheels are on the side that goes toward the tractor. It does make hooking up and taking off the back-hoe a lot easier.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Its been home for me for a few decades now. And an awesome one at that.
Originally being from Oceanside, CA my only real complaint here is the humidity. I also don't care much for the snow. I lived in Loveland & Bennett Colorado for 3 years.
But Mississippi has allowed me to realistically raise our 3 children on a moderate income. Even retired my wife after being a NICU nurse for almost 15 years to pursue her dream of homeschooling our 3 youngins. Some medical issues with mom kind of forced that sooner than expected, but not something I would think is possible in CA, atleast not on an auto techs salary lol.
My older brother and one of my older sisters still reside in CA, along with my pops. Of course he bought his home there in '83, of which he still lives in, and is basically now trapped around muli million dollar properties. He's in Vista, CA.
The amount of money my siblings have spent to maintain their rather high end of living out there, I could've bought half my county by now LOL.
Here's a shot of land for sale in our local marketplace bulletin throughout various counties to give you an idea of land prices.
Also 173 acres just recently sold that comes up right behind our property for $425k. That got quickly divided up and a 53 acre section directly behind me sold for $107k. Majority of land for sale around here will generally have premium timber to cut as well.
Hope this helps.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Have you gotten any news regarding your tractor @BBFarmer?
No sir.
No word after getting that settlement letter from KTAC two fridays ago. They at least got the check, so hopefully everything will move a little faster now.
I'm gone in like 12 days to for South Carolina. And i got a sneaky suspicion that it'll probably be ready right when I leave. It would be just my luck LOL.
  • Sad
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
A Tragedy and certainly one that we do not even want to read about but.....
I sawed these logs on February 8th and the customer's Kubota is seen in the background. Somehow he overturned that tractor yesterday evening and did not survive the accident. RIP Howard Adams.
  • Sad
Reactions: 19 users
Hugo Habicht
G1900
Jun 24, 2024
1,513
2,162
Ireland
No sir.
As far as I understand two technicians left the repair shop. Number of tractors to be repaired is still the same. Tractors used for commercial work get preference. Hence your tractor stays on the bottom of the repair list. I understand you do not want to put them under pressure, but I am afraid this is not the way to get your tractor back.
I accept delays in those cases, but after four (?) weeks I would certainly start making phone calls. You need your tractor too.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
No doubt. She's been gone since Aug 7. And they've been paid since Aug 29.
I didn't expect it back within a week or so, but definitely didn't plan on it being gone this long.
I got to take my oldest to a homeschooling function today around lunch and plan on swinging in on my way back.
It may be time to light a few fires under SOMEONE up there.
Or maybe just show up like I did 2 fridays ago. Then "magically" I got the approval letter within an hour of being up there......after the tractor had already been sitting there for a few weeks.
As far as I know it's still just getting a new hood, grill, and grill guard. Short of parts pending, my automotive mind says labor wise there aint much to that....but I could be wrong.
I agree ... Or at least see if they have a trade-in they could loan for a bit ...
That's something I was thinking of last week.
If they could at least let me borrow something, ANYTHING to get stuff handled before I head out in a couple weeks.
Otherwise, it could potentially be 6-8 weeks before I'm back on the farm and it'll look absolutely terrible not maintaining everything in that time. We usually have green grass well into January to.
My oldest is capable of running and cutting with the tractor. He always did an excellent job with our 3301. But the 3560 being slightly bigger, and cabbed, he had too many close calls. Can't turn him loose in that amount of money confidently just yet. Especially without me here. He'll definitely end up tearing something up if i'm not monitoring him. Standard teenager stuff.
lynnmor
B2601-1
May 3, 2021
1,769
1,577
Red Lion
Why not just run it like it is till parts are available? :unsure:
Bee-Positive
Nov 16, 2022
828
816
Amsterdam, NY
OSHA NOT approved.
Had a couple of shingles ripped off in high winds early spring. Wasn't leaking YET but figured I' make hay while the sun is shining. With a 12/12 pitched roof I can't just walk it to repair. My biggest ladder is getting to the point where I have difficulty even lifting it at my age. The ladder gets a little wobbly if I extend it too far so I used the BX to give her a lift. Chained her down real good, worked flawlessly.
Reactions: 11 users
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Allegedly, the tractor had to be at the dealer to start the estimate side of the claim process.
But I did just get home from swinging in there.
The service manager confirmed all parts are now on hand, and they're just waiting for a bay to open up and she's coming in, FINALLY.
Obviously, this doesn't mean i'll get her back anytime soon, but at least it's a step in the right direction.
Did see the largest kubota i've seen yet, an older M6 131, pretty cool. Ain't been around one of those before.
Reactions: 7 users
Hugo Habicht
G1900
Jun 24, 2024
1,513
2,162
Ireland
Allegedly, the tractor had to be at the dealer to start the claim process.
You are a gifted mechanic yourself, can't they just give you the parts and you do it yourself? For the labour they did not do they can give you a voucher for spare parts then, and everbody is happy.
6,189
One of our trails had several Virginia pines come down in due to a combination of age and winds a few months ago. The only reason for this particular trail is to monitor the our neighbor’s several acres of kudzu where it borders our property and carry out whatever activities are needed to stop it at the border. There’s an unavoidable swampy part of the creek bottom between here and home/shop area. It has just recently gotten dry enough to take the tractor through the swampy area without causing damage.
Below was the biggest problem with the old trail. I could remove the trees from the trail but removing this rootball and backfilling, particularly in tight quarters was questionable. Looking around, noticed this area, which is transitioning from pines to hardwoods, still has several Virginia pines that are nearing their 75 year +/- lifespan. Decided it would be wiser to reroute the trail around the rootball and through an area where the pine to hardwood transition is nearly complete.
Tried to avoid any trees bigger than about 2”. That was mostly chainsaw work. Tractor was needed to clear deadfall and grade out a couple of old sawdust piles that were left over from last time it was logged off, about 80 years ago.
After finishing the trail, went back to the fields near the house where we have a few Ailanthus altissima on the edges. Had decided to remove them to eliminate the preferred food source of the Spotted Lantern Fly. IMG_6419.jpeg Was thinking we had maybe a half dozen little ones and started grappling them to the nearest brush pile. The more I looked, the more I saw. Wasn’t long before I decided to change plans and get out the chipper. IMG_6420.jpeg Didn’t take long at all to chip everything. Biggest tree was about 6” at the base and maybe 20’ high. Chipped every bit of it.
Then moved to the brush pile and chipped all the stuff I’d moved there earlier. IMG_6450.jpeg
Reactions: 9 users
