BX mounting brackets for LA344 (LA344s)
MGnoob
L175
Aug 27, 2025
20
Massachusetts, USA
I’m looking for la344 loader mounting brackets or someone to make me a template of the ones on their machine with a few measurements. I won’t be spending $1000 to buy them from Kubota
I’m going to put in LA344S on my L175.
I have the Loader minus the mounts, joystick, tractor side hydraulic hook up.
in an ideal world, I’d get the original brackets and make an adapter plate (and subframe) so I wouldn’t have to modify them. I’m comfortable just making new ones to fit my L175, it would just be nice to have all the original stuff.
it would also be nice to have the tractor side hydraulic connector. If it proves to be very expensive, I’ll just add regular quick connect..
I’m likely gonna put the cheapest joystick I can find out there. But I am contemplating
adding a third function….
any help would be appreciated, as always, I’m trying to do this as cheap as possible.
i’m aware of the implement will be a little slow mostly the bucket.
Any help would be appreciated, as always, I’m trying to do this as cheap as possible.
MGnoob
L175
Aug 27, 2025
20
Massachusetts, USA
I suppose I could always go to the dealership and make me a cardboard stencil and do some measuring aswell… just curious if anybody else already has the information
2,201
Not sure where you are trying to hook into the tractor hydraulic system but there might be a place to add an adapter block.
See this thread for the cover that may fit your L175. It did fit my L185F.
MGnoob
L175
Aug 27, 2025
20
Massachusetts, USA
I already have a hydraulic take off there.
I’m trying to get the mounts that go on either side of the tractor that the quick connect from the Loader sit on and lock onto.
I’m sure we’ll be discussing my high hydraulic options later.
it’s in the photo above. Part 010 and 050.
I have the actual part numbers. But searching that was only shows new ones for sale.
2,201
I don’t understand your statement in your first post if you already have the hydraulic take off. But really don’t need to understand.
MGnoob
L175
Aug 27, 2025
20
Massachusetts, USA
my L175 already has the plate to take hydraulics off of the three-point hitch.
The Loader, I have has the connector that would plug into a BX tractor
I do not have the part that would go on a BX tractor to receive the hydraulic connections from the Loader because I have an L series tractor
Just put the hydraulics aside for a minute, I’m looking for The mount that let you put the loader onto a tractor that go on either side of the tractor as in the photo above.
