Grease Fitting on BX Deck
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
Hi-
Doing my annual deck maintenance and noticed that the idler pulley appears to be missing a grease fitting on the top. That said, I’m not sure there has ever been one, though the hole appears to be threaded…so now I’m curious; should there be one and if so, anyone know the size?
Deck is a RCK48-18BX and as far as I know it’s original to my 2012 BX1860.
Thanks for any help!
armylifer
Mar 26, 2013
2,331
1,086
Thurston County, WA
I don't know about your deck but the manual for my RCK54 shows a grease zerk on top of the idler pulley and one on the tension arm.
Orangeglow
2015 BX2370
Jun 19, 2014
423
236
Prescott, Ontario
Yes, there should be a grease fitting on that pulley. Take the one off of the other pulley and see if it screws in properly on that pulley. If it does, go get one at your nearest location that sells them. Make sure you take the old one with you to get the proper size.
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
There is a grease zert on that pulley my RCK48-18BX deck; and it’s shown in the manual as a grease point…see the circled 2 in the attachment.
bluedunn
Aug 29, 2019
304
40
Thetford, VT
Ok, thanks for confirming guys. Not sure what happened to it, but I don’t remember there being one in that location since I got the BX. No play in the pulley so I’ll thread in a new fitting and grease it up.
3,767
2,177
Install a 90-degree zerk, not a straight one.
