Hydraulic leak on Flail Mower
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
165
72
NH
I recently bought a Del Morino Centurion Super 158 flail mower. I have noticed that with the mower lifted off the ground that after a few minutes the mower will start to tilt down. Would this be a leak in the rear remote valve or with the mower hydraulic cylinder? How can I tell which one it is?
Is this normal?
2,198
There is a speed control valve that you can probably put into a lock position. Put it into that position and see if it falls. If it does that indicates the cylinder is leaking past its seal.
I would assume that the fall rate will be very slow in the lock position so would probably just use that to hold the flail mower up. But why are you holding it up for use?
imarobot
Apr 18, 2025
165
72
NH
I don't think there is a speed control valve, although I would like to put one on for both levers. This thing is very jerky when swinging or tilting. Takes a lot of fine lever movement with two hands to control it smoothly.
I don't cut with it in the raised position, only when transporting, making sharp U-turns, backing up etc. and typically have to level it off again if lifted more than a few minutes. It even tilts down a little bit when on the ground due to a pivot in one of the lower 3 point links. I notice that when I lift it off the ground it is tilted a bit down.
2,198
Oh sorry I thought you meant the THREE POINT HITCH, not a hydraulic cylinder on the mower or tractor.
You can do a couple of things like adding a dual pilot operated valve to the cylinder that locks it in place when not being adjusted. That eliminates “float“ on that cylinder if the valve is capable of float.
To slow down the rate of movement you can install a needle valve or a flow restrictor fitting into the hose or cylinder ports.
You can do the restriction and the pilot valve both In unison on one cylinder.
JonM
Nov 29, 2024
102
195
wisconsin
Is this normal?
probably has air in the hydraulics. just need to rev up the tractor and cycle the hydraulics a few timea to work it out
common with new equipment. check ypur hydraulic levels anytime you add a new piece of equipment after a short bit of use
2,198
And that leak down can be either a cylinder or a valve. Disconnect both lines (assuming they have a disconnect fitting on the hoses) and see if it locks in place (cylinder is NOT leaking, it is valve leaking).
imarobot
Apr 18, 2025
165
72
NH
Good point, but I've run this thing for several hours now so I'm guessing it's not air.
I did check the fluid level and it is good.
imarobot
Apr 18, 2025
165
72
NH
Gotta give this a try
imarobot
Apr 18, 2025
165
72
NH
Dollars to donuts its the valve. New cylinders dont leak but valves all do.
And you are right, what would prefer dollars or donuts?
I disconnected the hydraulic hoses, and it didn't drop.
Didn't think of it at the time but I am going to connect the hoses to the other valve and see if that does the same thing.
Is this behavior to be expected?
5,494
Coffee rolls from Dunkin please.
That behavior is to be expected. Spool type control valves do not have shutoff seals. They rely on a very close (a few ten thousandths of an inch) cleaeance fit in the housing for the shutoff function. That clearance is both a pressure and fluid leakage path. Valves with tighter spool clearances and manufacturing tolerances cost more and leak less but they all leak. Pilot operated check valves (poppets) on the work circuits are commobly used to mitigate that leakage.
imarobot
Apr 18, 2025
165
72
NH
I'll do what I can, but coffee will be cold and donuts stale by the time they get there.
While you are waiting, could you please explain what you mean by "Pilot operated check valves"?
5,494
I am a very patient man :ROFLMAO:
Pilot operated check valves are poppet type positive shutoff valves that are installed between the work portvand the cylinder. They are sometines called "lock valves" and prevent reverse flow from the cylinder. When pressure is applied to one side of the circuit it acts on the opposing check forcing it to open permitting return flow to the valve. When used in asirs on a double acting cylinder they are called dual pilot operated check valves (DPOCV). Hydraulic top links often come with a DPOCV mounted directly on the cylinder to prevent drift - see picture. You can buy them standalone abdcadd them to equipment as well.
2,198
A simple way to think of these is that they let the “pilot” adjust the cylinder in either direction by using the control valve. Then they act as a check valve and hold the cylinder in place until the ”pilot” adjusts it again.
imarobot
Apr 18, 2025
165
72
NH
Thanks. Coffee and donuts for you too?
I'll have to investigate these things. I never knew how complicated hydraulics could be!
imarobot
Apr 18, 2025
165
72
NH
Found a of video which explain the operation of a pilot valve on YouTube from LunchBox Sessions. The video explains an issue with the valve being jerky when lowering the load as the pilot opens and closes with the pressure changes. With an orifice added this does not occur but the speed of lowering is much slower.
A follow up video explains the operation of a counterbalance valve which overcomes this.
In addition to eliminating the valve leak problem I would also like to slow down the movement of the cylinders so I'm thinking a pilot valve with the orifice may also accomplish that too.
Any thoughts?
5,494
Any thoughts?
I have DPOCV on my remotes. They are a little noisy and "jerky' on opening but otherwise smooth. I would suggest adding one or more to your mower along with restrictors in the implement hoses to slow the cylinder(s) down. I am using these.
imarobot
Apr 18, 2025
165
72
NH
Is this the correct restrictor?
Hydraforce NV08-20A-0-N Flow, Non-Compensated, Needle Valve
Would I need to connect one of these to each side of the implement cylinder or just on one side? As you would expect, the cylinder reacts faster in one direction than the other because of the cylinder volume difference. I'm thinking just having one on the cylinder shaft side would be sufficient. But then again, I ain't no hydraulic expert. Far from it.
imarobot
Apr 18, 2025
165
72
NH
Not even close. Put one of these on the rod end port of any cylinder you want to slow down. You need to ID the thread type and size that matches what you currently have on the cylinder.
So, is the Summit Hydroforce NV08 I tried to link above the wrong choice for a restrictor? I liked the idea of having an adjustable orifice.
I used the term "shaft" instead of "rod" so I at least had the connection to the right end of the cylinder correct!
The way I understand this is that I will attach the DPOCV to both ends of the cylinder using metal tubing between the cylinder ends.
The restrictor will go on the hydraulic hose that goes to the rod end of the cylinder. Should I insert this on the hose end at the connector to the tractor rear remote or on the other end of the hose at the DPOCV rod end of the cylinder?
Thank you for your patience and helping me understand this, I hope to get it right the first time! :)
