Problem Description
I have a 2019 M4-071 with about 220 hours on it. I was brush hogging recently and things were going well. Later on that day after I was done, it started having a problem where it would not move forward when shuttled to F and when its shuttle to N it tries to go in reverse. R is still reverse.
Sometimes the tractor will move normally, but usually not.
So the behavior is like this given the tractor is in gear, parking brake is off and foot taken off clutch:
Has anyone else seen anything like this?
Troubleshooting
I'm no tractor tech, but I've tried to do some troubleshooting after I got the shop manual.
The dash panel where it shows F/N/R shows the correct position, and it does complain with the warning beep if you try and put it into F or R with the parking brake on.
I found in the shop manual about testing the voltage at the shuttle sensor wiring (shuttle sensor shown in shuttle_sensor.png) harness and it appeared to be correct (5 volts).
I found in the shop manual information to get the tractor into TST-1 mode where you can observe various readings and check error codes (tst1_sensor_info.jpg screenshot) and observed the values under certain conditions:
T12 and T13 are at about 2.2 and 2.74 volts when the shuttle is in neutral (respectively).
T12 and T13 are at about 0.62 and 4.3 volts when the shuttle is in forward (respectively).
T12 and T13 are at about 3.81 and 1.13 volts when the shuttle is in reverse (respectively).
Those seemed to be in range based on what I think I read in the manual.
Since it does move smoothly sometimes, I suspected something electronic. I replaced the shuttle sensor located under the shuttle lever (shuttle_sensor.png screenshot) but it did not fix the problem.
The manual says the ECU takes the signals from that sensor and the shuttle switch (which appears to just detect if you're in neutral) and activates the F or R solenoids, so I guess those are just getting a bad signal somehow.
I see a page about testing the shuttle solenoid valve wiring harness, so will give that a shot next (shuttle_solenoid_valve.jpg screenshot).
- I shuttle to F, the tractor does not move forward.
- I shuttle to N, the tractor starts moving in reverse.
- I shuttle to R, the tractor starts moving in reverse.
Troubleshooting
