mx5200 dt clutch
crobins
mx5200
Aug 18, 2025
14
mcconnelsville, ohio
Any one know of a after market clutch for these that are beefier than stock. mine has around 575 hours on it and just went through the first one
10,194
The stock clutch and pressure plate is the heaviest you'll find.
Been doing a lot of loader work with it?
Or was the clutch not adjusted properly and slipping?
crobins
mx5200
Aug 18, 2025
14
clutch was a little tight but the answer is yes a lot of loader work. originally noticed it burning some while digging holes to bury dead animals over winter. I think a lot of back and forth and digging frozen ground. finished it off by brush hogging new ground and pushing over autumn olive bushes
10,194
I would put a good aftermarket clutch and pressure plate in it (will save you a ton of money) and keep a really close eye on slipping the clutch and clutch adjustment.
crobins
mx5200
Aug 18, 2025
14
Looks like it will save me around 6-700.00 im not aware that i slip the clutch but will def be something I watch for now.
Ok new pressure plate and clutch installed replaced missing clips greased everything and trying to get back together have bolts all lined up but just dosent feel right I feel like I’m forcing it is there a trick I’m missing
10,194
Did you align the clutch disk to the pilot bearing or the crank?
Do you have everything square and level?
Did you remove the propeller shaft?
crobins
mx5200
Aug 18, 2025
14
I could not locate a pilot bearing on this tractor I purchased a clutch tool and aligned as best as I could to the crank. I also called my local dealer and they assured me this unit dosent have a pilot bearing. As for level Im working on gravel in a driveway so not the easiest to do. Wouldnt aligning on bolts do the same thing. And no I didnt remove the shaft. But tractor is in neutral.
10,194
You must remove the propeller shaft to put it together.
Your more than likely not aligning up on the splines on the coupler.
Yes no pilot bushing, That model has 2 sets of splines that need to be aligned from the transmission input, one spline is in the hub on the flywheel and one on the clutch disk.
DO NOT force it together, doing so will almost guarantee you will break parts.
You can manually turn the crankshaft on the engine to get them to align.
crobins
mx5200
Aug 18, 2025
14
I removed the pin 030 and the set screw then slid the shaft tube back. the shaft is not all the way through the housing it is just starting to clear it. There is around an inch of clearance before it hits the coupler. I was thinking the inner was for the pto shaft. I am going to try to split it again and take a look see. Im thinking the same I could spin the engine pretty freely until it gets closae to being inplace then it gets pretty stiff. Im thinking the inner shaft isnt dropping in. If I rock the pto should this move the inner shaft.
