L3800 HST "Runaway"/over rev
Buzzaro
Kubota L3800, Kubota Z411KW
Aug 31, 2025
California
Title is a little misleading, I don't think it's a true runaway condition but unsure how else to describe it. I've had this happen twice now. Mowing fairly thick grass with a Gearmore gml69 flail. A little oversized as the machine is working pretty hard. The engine temps are climbing but not into the red (radiator and screen has been checked, cleaned, and blown out). So while mowing under heavy load and full throttle (RPM's at the PTO 540 mark) the engine RPM's suddenly climb and the tach is pegged. Both times I've immediately pushed the throttle level all the way back to idle but the machine keeps cranking and black smoke starts to come out. Each time I've turned the key off and then the engine does shut down. Now all this take place within 2-4 seconds so to be honest, I am unsure if the RPM's begin to drop before or after I've turned the key off. Each time it fires right back up and continues to operate normally. I have checked the mechanical linkage from the throttle lever to the injection pump and it moves freely by hand through it's full range and returns normally by the spring.
Looking for ideas on what the issue could be.
Thanks
3,104
That does sound like a true runaway situation.
It may be sucking oil from the crankcase or somewhere to run on that instead of the fuel.
Look into the air intake system to see if there is an oily film, find out what is connecting the air system to the crankcase and fix whatever may be going on.
I would recommend NOT using it until you find the problem.
loggin
MX4700
Sep 4, 2021
111
39
canada
Thanks
It looks like your model has the interim tier 4 motor which I believe has the vent on the valve cover with a tube that goes to the intake. This vent releases crank case positive pressure. I hypothesize that under full throttle and high load you might be getting greater blow-by at the piston rings. This might be enough to force some oil into the vent tube and then be sucked into the intake thus causing a temporary run-away condition.
Just a thought..
Buzzaro
Aug 31, 2025
California
Just a thought..
Thanks. I just checked that this morning and there didn’t seem to be any oil in the intake. How much oil would I expect to feel or see to be an issue? I wiped inside with a white rag and while it was ever so slightly oily, there was no black residue on the rag. More oily in the way that sometimes happens when you grab the diesel handle at the pump, maybe even less so.
loggin
MX4700
Sep 4, 2021
111
39
canada
Have you checked the oil level for any change? Burning oil would reduce level. Fuel or hydraulic fluid getting into the crank case would increase level. If the oil level is high this would increase the likelihood of it being sucked into the intake.
It is hard for me to know how much you would see at the intake. I would suspect you would see some sign of oil. Perhaps someone that knows more about that can chime in..
Buzzaro
Aug 31, 2025
California
I had just changed the oil so I checked the dipstick and it was way way over full. Seemed like pretty clean oil, no diesel smell, not milky or thin. A google search had someone else with the same overfill issue. I had added the 7.5 quarts the manual said, but maybe I didn’t get it all out or something. Plus I didn’t check did check the dipstick when I filled it up. One more lesson to learn the hard way. In any case,I removed some oil down the correct level and then I risked it and ran the machine again with the flail. Ran normally, and the temp wasn’t climbing as the day before. Hopefully that was the issue and it’s not a lesson I learn the REALLY hard way.
3,104
Keep an eye on the oil level for a couple of weeks until you are sure it is stable. There may be some seal failure on the hydraulic pump that lets hydraulic fluid get into the engine case. That may not be possible on your tractor but was on mine.
mdhughes
L3901DT
Dec 10, 2014
1,465
1,545
Ste Geneveive county, MO
There are two drain plugs in the oil pan, if you didn't drain both sides you would have over filled it.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
75
12
Sounds to me like a bad injection pump or possibly worn out cylinders / pistons
Either way I would start with a compression test first
Buzzaro
Aug 31, 2025
California
Not a big update but just to follow up. I verified nothing sticky, at least externally, on the injector pump. Pulled oil out to get it down to the correct reading on the dipstick. I had drained both sides and the oil I pulled out was pretty clean so it doesn’t seem to have mixed with much, if any, oil left on the engine. The temps here are cooler but in the last couple weeks it hasn’t wanted to heat up like it had been. After putting a couple hours on it, the oil level has remained very steady as far as I can tell. I have not done a compression test as tech 101 recommended, so I can’t say if there’s anything there. No further issues and I have run the flail. I’m not saying the oil overfill was 100% the issue but I’ll be testing that theory for for the foreseeable future.
thanks everyone
