L175 engine front shaft
MGnoob
L175
Aug 27, 2025
22
Massachusetts, USA
I know this has been discussed in depth.
Does anyone have a definitive answer where to get a female shaft with the appropriate splines to attach to the front motor shaft?
10,681
Your going to get the same answer that is been the normal answer to this question.
Almost impossible to find any of the original shafts or parts for that system.
And the ones that I have seen are worn out and usable.
They even abandoned and obsoleted the original shafts early on, as the failure rate was to high.
There was a replacement setup that was larger and more robust, but that failed also, and was also obsoleted.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
125
115
Lopez Island, WA
If this setup is similar to the one used on the B5100 tractor, I was able to make a sleeve that just slides over the male splines in the front of the crankshaft, and then transition to a 5/8" drive for a hydraulic pump. A shrink disc anchors the sleeve over the splne; it's been in service for almost 10 years w/o any issues.
MGnoob
L175
Aug 27, 2025
22
Massachusetts, USA
This is similar to what I was looking for…
what I don’t understand is how the shrink disc over the sleeve you made grabs onto the splined shaft.. you didn’t split the sleeve you made so that it can compress around the shaft?
I understand what you did I think I just don’t understand how it works.
A little more explanation would be helpful, but I believe you have answered my question.
10,681
Look at the picture on the paper, it's split.
The other way to do a retro fit is to bolt the flange to the crank pulley.
MGnoob
L175
Aug 27, 2025
22
Massachusetts, USA
thank you I misinterpreted your drawing. Both options are similar to what I figured had to be done. You could probably hand make something too. That would engage the lines. It’s just not the most convenient location.
All right, thank you very much. You’ve been very helpful. I’m sure I’ll have more posts related to my l175..
I’ve played with it a little bit, but now it’s time for her to do some work. I’m gonna do some brush hogging weather, depending.
barts
Feb 10, 2015
125
115
Lopez Island, WA
The shrink disk will compress a sleeve that is solid; it doesn't need to be be split. The shrink disk has a very shallow internal taper that develops a very substantial compression force; of course, this means that the tolerances are pretty tight on the internal and external sleeve dimensions.
I ended up using a metric dimensioned disk because they were available surplus and affected only the OD of the sleeve which I had to turn to z finished dimension anyway.
MGnoob
L175
Aug 27, 2025
22
Massachusetts, USA
Excellent. Thank you I’m also on the lookout for the pulley that goes on that shaft I may utilize that for the attachment point if I pursue it. fingers crossed, I should be picking up a loader on Wednesday. This one’s on a machine and is functional. I believe it to be running off the machines hydraulics, but I’m not positive. Either way I’ll set it up on my tractor in whatever configuration is currently in for now..
Last week I looked at a workhorse loader.. I wouldn’t even want to spend $200 on it. I wish there was stickers on the one I’m likely to buy so I can tell what model it is easily but regardless, it’s the correct one. It’s coming off a L185 and shouldn’t be much for problem to get it on my l175.
