Stihl Kombi LIVES!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Sorry if this is old news to those of you with more life experience. It's something that I've never heard of in my 76 years. Guess I haven't gotten out much.
My Stihl 94R went from running fine to barely running yesterday till it finished cutting the weeds along the creek banks. I removed and cleaned the filter, cleaned and gapped the little spark plug and scratched my head. It wouldn't even rev up at that point.
Mentioned this to my BIL last night and he said he had the same thing happen to his Echo trimmer. He took it to a shop for repair. They fixed it while he waited - less than 5 minutes. The fix was to remove the spark arrestor, zap it with a propane torch to burn off the carbon and that's all. He told me he's done his a few times since then. I did mine this morning and after putting the spark arrestor back in it ran like new.
It couldn't be more convenient. The only things that need to be removed are a single screw and the arrestor itself. Pull the screen out with a long-nosed pliers, grab the torch and you're done in no time.
OntheRidge
Nov 1, 2020
494
585
Old school, we would take those out as soon as we got a new saw. Now, doing that will blow up your saw/trimmer/etc. So, yes, clean it, reinstall.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,237
Ireland
Thank you very much for the tip !
I had three small engines that stopped working recently, a Stihl chainsaw, a Stihl strimmer and a whacker plate with a Honda engine. In all cases the problem was the spark plug. Put new ones in, ran fine. Checked the old ones: gap too small. Widened it, put in old spark plugs, everything back to normal.
So can anybody explain to me how the spark plug gap can get smaller??? I always thought the electrode burns off, hence the gap getting wider.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
That’s one of the first things I check when any 2 stroke comes across my bench.
lynnmor
B2601-1
May 3, 2021
1,795
1,603
Red Lion
This video will explain it. I solved my clogging problems by using Ace Hardware oil.
Brad M
L3301
Mar 23, 2023
Springfield MO
The only way Ive seen gaps get smaller is when an engine has detonation or pre-ignition.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
Great video @lynnmor, Chicanic is awesome.
So I run a bunch of landscaping equipment (while pretending to know something about landscaping) and use STIHL oil in my STIHL saws and KM-131R. But, I also use the highest octane ethanol free petroleum distillate I can get, and watch the mix ratio closely, and make sure the mix isn't old enough to have gone stale. I rarely need to run full out and have had no problems (and do wrench my own engines).
STIHL oil does not run well rich. If it says 50:1 you'd better run 50:1.
Now the Johnsreds or any other engine made in China saw (McCullough included), those spec. 40:1 and need to run at 35:1 or 30:1 to have a long life, or they burn up as soon as something is a bit off. They get Mystic 2-stroke Marine oil because it's great quality (according to lab results), runs clean in a heavy oil mix, and is quite affordable (smells like a pot farm on fire when working in a ravine without wind though).
Remember I only pretend to know what I'm doing, so no need to get all bent if you don't agree.
