I have elderly relatives that don't have the resources to do the work themselves or to hire someone to take care of their gravel driveway, so I volunteered. My understanding is that nothing has been done in 30 years and it shows, many deep potholes along with crevices from running water.
I've never done this type of work, I did my best using what I had on their 300-400 foot driveway, a box blade. My understanding is that when there's potholes, one needs to grade to the depth of the pothole and that's what I did. While grading, I noticed that there was a very thin layer of gravel, mostly dirt mixed in. in the end it looked much better than it was and one can actually drive on it now.
The continuing issue is water running down the drive, into the parking area and into the garage. It appears from the first image the driveway is lower than both areas to the sides and acts as a channel for the water. I was told that there once was a berm where the blues lines are, it disappeared long ago, the idea was to direct the water to the left of the image, that didn't work out well because it forced water into a pole bar.
My questions are:
#1 what type of gravel do we need to put on top for here in Michigan, most of what's remaining is just dirt with a little bit of gravel mixed in.
#2 How do I grade the driveway to keep water from running down the drive into the parking area and in the garage. In the third image, from the parking area, the yard runs downhill into a pond.
#3 What would be the best approach to fix this going forward, culverts, drain tile, etc??
My questions are:
