Valve leak troubleshooting
awesome
L2502, BH77, K54-22-06B
Sep 16, 2018
320
215
ottawa
I have this Vevor valve that I use for my rear aux.
The female quick connects are positioned verticaly, so facing up.
While operating the tractor, and without using the valve, I notice that the QCs fill up with oil. What this tells me is that the valve is seeping oil, and the 4 QCs also.
Would this point to all 4 qcs being faulty as well as the valve? Or is this just normal behaviour? In this case, how do people deal with oil messes over their tractor all the time?
9,419
Get a good set of QC's and you'll be a lot happier.
It will hopefully keep the cheap valve at bay.
Fedup
336
128
Winchester
Doesn't have to be a cheap valve. I've seen the same problem with Kubota valves and couplers. A male end with a pipe plug threaded into it installed in the couplers works too.
4,197
If those QC’s are facing up all the time, don’t they get dirt trapped in them?
I think that could be problematic.
Also, has it done it since "day one”?
Lastly, just out of curiosity, how long does it take to fill up? ……(I.E……seconds, minutes, hours, days)
awesome
Sep 16, 2018
320
215
ottawa
Yeah, they are facing up but I put a plastic bag over them usually. I should get those rubber plugs though.
It has done this pretty much from day 1. They fill up within 30min I would say
4,197
Unless there is some sort of “re-build” kit available, which I would be dubious of doing, It sounds like you got “Vevor’d” :LOL:
Don’t misunderstand me, I understand the reasoning behind getting stuff from Vevor, and I have ordered lots of Vevor stuff, but not all of it is/was “high quality stuff”.
Could you mount it vertically so that it would just “drip away” during use, then wash it once in a while?
awesome
Sep 16, 2018
320
215
ottawa
Yeah, I'm fully aware that I should not be expecting much from Vevor. But I first wanna make sure that this is indeed because of vevor. If everyone tells me that it's completely normal to have oil all over a tractor all the time then I'll just let it go.
5,775
Couplers are positive shutoff devices and are not supposed to leak.
Spool valves are not positive shutoff devices and they all leak. Some leak more than others.
Do the couplers fill up to overflowing?
awesome
Sep 16, 2018
320
215
ottawa
yes, they overflow.
I got the couplers from aliexpress BTW. So if buying good couplers solves this issue, then I'll buy a new set. But I won't bother replacing them if that won't do any difference.
5,775
yes, they overflow.
I would replace one coupler and see how it does.
