B2601 valve stems different?
milanmark
B2601, Bucket, Grapple, Brush hog, stump bucket is ordered!
Jul 7, 2021
82
40
Milan, MI
I have a B2601, left front tire looks low so I tried to check the pressure. Tire gage didn't fit, so I just tried putting air in, the inflator chuck didn't work either... something different with these? Tires were loaded when I bought it (new). Help please!
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
793
690
E.
Your dealer may have upgraded you to a more HD valve stem. Maybe a 16mm stem vs the lighter 11.5mm stem
BAP
Dec 31, 2012
2,960
1,065
Take a picture of the valve stem from top and post it. It will be easier to help you if we can see it
milanmark
Jul 7, 2021
82
40
Milan, MI
The position it's in gonna be hard to get a good pic but ill try next time im out... stopped by the dealership the srvc mgr sez should be the same as an automotive valve stem.... he wants a picture also! Going to take my pancake compressor out tomorrow and try that see if that works....
2,187
You may be missing part of the valve stem??
Look at any of the other valves that can fit into your air chuck.
BAP
Dec 31, 2012
2,960
1,065
They may have forgotten to put the adapter in the valve stem. It could have the large bore valve stem that is used on big tires and they require a screw in adapter to use regular air chucks and gauges.
