Woods BB60
sgerksinwi
L2501 DT
Aug 1, 2025
20
Wi
Will a Woods BB60 (older model) rotary cutter be to much for a L2501 kubota?
This one is a model before the BB60/30/50
11,198
Your on the light side of having the recommended HP to run it.
You have 20.5 PTO HP.
3,953
2,455
I think it'll work fine. You may be more comfortable with some front weight.
sgerksinwi
L2501 DT
Aug 1, 2025
20
Wi
I just look at the Kubota
Specifications & Capacities
RCR12 Series
Model Numbers RCR1242 RCR1248 RCR1260 RCR1272
Weight (With shear bolt
Recommended Tractor
Horsepower
18-40 hp
(13.4-29.8 kw)
20-60 hp
(14.9-44.7 kw)
25 -60 hp
(18.6-44.7 kw)
Power Take-Off Speed 540 rpm
Gearbox Rating Horsepower 60 hp (44.7 kw)
Gearbox (Speed up beveled
Chad D.
255
132
Eugene
You’ll be fine. May not be able to go quite as fast as a fella with 40hp on his PTO, but it’ll do the job for sure.
