B7500 start problem
2,435
As stated by @North Idaho Wolfman the black smoke indicates over fueling. I would do something with the injectors at this point I guess…
1) inspect the spray pattern
2) have injectors tested and rebuilt
3) replace injectors with new OEM injectors
Hopefully you can wait on more experienced advice and see if there is any consensus. I just don’t see how they would just fail in a sudden manner.
Since you were using it in a firefighting mode can you recall anything that could have harmed the engine other than running low on fuel? Was it thick smoke being sucked into the engine? What did the air filter look like when replaced? Was there anything in the smoke that could have effected the combustion chamber?
I am guessing something may be damaged but I believe your tractor is old enough to be purely mechanical on the fuel injection system so can’t really see how the fire would damage the injection system.
Did you cut open the fuel filter(s) to see if there was anything that was suspicious inside?
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thanks Russell. Yes, tractor front was in high heat with lots of thick smoke with wind. Tractor was sucking dirty air into engine intake and fuel tank cap. The outer air filter was dirty, inner air filter was clean. I will look for fuel filter, hopefully it is still in my garbage, but it was dirty. Fire was from dry, tall, wild grass so it was a normal fire i.e. no chemicals. Bucket and front tires took a beating, but remainder of tractor seems fine. Front grille is plastic, looks good, no melted spots, and no deforming. Not very much wiring in this tractor but wiring around engine and starter is Ok. No sign of melting anywhere. Bucket hydraulic hoses are fine. The thought crossed my mind that one or two injectors could have crap inside them.
2,435
Well one other thought on it is maybe it overheated? I don’t know why that would keep it from starting now or why it continued to run until parked though.
I would look in the front of the radiator at a screen and make sure it is not melted (it is plastic on my tractor). If not melted I would clean it and the exterior fins of the radiator just to be safe.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thanks Russell... My tractor must be old style because the screen in front of the rad is ridgid metal with metal framing. There will have to be a comprehensive maintenance done on the cooling system, hydraulic oil front and back, repaint on bucket and bucket rams, etc. This tractor has always run cold. I don't think it overheated. It definitely didn't boil over.
BAP
Dec 31, 2012
3,042
1,160
Follow Russell’s advice on checking the injectors. My Dad had a B7500 and at one point, 1 injector crapped out and the tractor would not start.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Ordered three new OEM injectors. Could have paid to have them tested but decided tractor is 21 years old in any case, money better spent on replacement. Face the situation and be more confident in operation. Cost $300.00 CDN each or about $28.00 US (ha ha)
2,435
Just to let you know that there are some sealing washers under the injectors that you could replace also. They are copper I believe so may be hard now and not seal well. You can anneal the old ones if you want, I just tend to replace since they are normally inexpensive.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thank you Russell. Yes still smoking black smoke when cranking.
So I received new OEM injectors. Took off the injector fuel overflow pipe, pipe is plugged between center or middle #2 injector and number #3 injector (closest to rad). Openings in overflow collars are extremely small, no way any kind of wire will fit into it. Will try compressed air but no way of knowing if piping will be clean completely so there are no future injector plug ups. Can not order new overflow pipe until Tuesday because of Labor Day holiday.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
One other note. Is there any reason that a person should not separate the collars leave some piping stubs attached to the collars, discard the hard pipe between the collars and use hose and clamps between the collars? Both ends of the overflow pipe header are hose anyway - one back into the injection pump and one back to the fuel tank.
2,435
On my L185 there are rubber hoses used for all the over flow between #1 and #2 and the tank. The clamps are pretty simple spring wire clamps so not able to hold too much pressure.
Could you post pictures of what you have going on? I would like to see what is going on out of curiosity.
Your illustration looks similar to what my tractor looks like except more complex.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thanks Russell. My tractor is the same as yours. Middle injector #2 relieves excess fuel to #1 and also to #3. From #3 to injector pump via rubber hose, from #1 to fuel tank via rubber hose as well, with simple spring clamp at joints as you point out. In my tractor excess fuel over flow line from #2 injector to #1 injector and from #2 injector to #3 injector is 3/16", appears to be brass. I can blow air from #1 to #2 thru the brass tubing. I cannot blow air from #3 to #2 indicating blockage.
Since it is hose leaving injectors #1 and #3, i am thinking one should be able to cut the solid tube over flow line berween #2 And #3, clean out the debris and use hose to reconnect.
9,491
Yes you can cut the hard lines and replace with hose sections.
4,225
At the risk of sounding condesecnding(which I am not trying to be), or winning the “Captain Obvious” award…..
At any time, was a can of ether (starting fluid), used to “help get things going”? (even one time)
2,435
Thank You Wolfman.
Russell - did I clear things up in my explanation?
Yes you cleared it up.
And to be perfectly clear, the diagram above is for your tractor not mine. My tractor dumps all excess fuel back to the tank, while yours circulates some back to the pump and some back to the tank.
If needed, you should be able to remove the injector lines and remove the fuel return portion of the injectors to clean them out. But you may not be able to buy those parts so be careful.
It is just curious that someone used hardline to replace rubber hoses. But perhaps that is how the factory did it? I don’t know. Not sure how hard line is connected to the injectors either.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
No starting fluid used. I have read that somewhere but do not know what starting fluid does that is bad.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thanks Russell. The injector fuel overflow pipe is a factory item. I will post a picture later. I will take a picture of the injector assembly to possibly show how it relieves fuel to the solid "injector fuel overflow pipe" as Kubota calls the set-up.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
OK Scissors, i did some reading of previous posts on this forum and note the consequences. One would think Kubota would have a warning on the air cleaner that slaps a person every time they open the hood.
LawEd
B7500HST
Jun 5, 2025
24
10
Alberta
Thank you to all for providing suggestions to fix my tractor. Tractor is running with no problems.
Thank You!
