B8200 hst d trans case
3,017
Do you mean swap one full case out with another full case or do you mean just replace the external case and put the old internal parts in that case?
10,868
You need to be very specific in your verbiage, there are mutiple "cases" in the rear end on that tractor.
Here are just a couple:
3,017
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
181
Attalla Alabama
mossycreekoutdoors.com
How difficult would you say changing out trans case would be. I do mechanical work, but not on tractors.
If you do mechanical work your good to go. All the bearings are slip fit in the case. Bearings are light pressed on shafts. Take lots of pictures as you go. You'll have to remove brake rods, diff lock rod, hydraulic lines and some electrical and then split it where the tunnel connects to the hydrostat. Remove hydrostat and 3 point cylinder cover then you can remove the transmission and swap internal parts. Could be done in a day but easily a weekend project. Order seals and gaskets ahead of time of course.
Millermaxx
B8200hst-d
Aug 20, 2023
9
Arkansas
Man thank you so much for the info!
Millermaxx
B8200hst-d
Aug 20, 2023
9
Arkansas
I will triple check the numbers thanks for the infornationn
If you need a case or any parts id have most all of it here.
I won’t start until I have everything I will need or may need and I’m going to study ony. It for a bit there is no rush and I don’t want to do it twice is there anything I. Need to check when it’s apart while I’m there
Millermaxx
B8200hst-d
Aug 20, 2023
9
Arkansas
What is wrong with it?
the
The pto coupling pin came apart and coupling knocked hole in case
