Rc60-B for sale
gunnerdog1
B7200
Feb 19, 2015
Owego, ny
Have a mower deck RC60-B off a B7200 with all mounting brackets for sale! Had a small rust spot welded over on one side off deck! Gear boxes and spindles are all good! Been using it right along! Been stored in my pole barn! Asking $400.00 for the complete setup!
Dirtndents
Kubota B7200D
Oct 26, 2025
Greetings gunnerdog1,
This is my first post, so I'm still figuring out the site navigation.
I'm interested in the mower.
Just purchasing a B7200D. Deposit is down, and I'll pick it up soon.
It has the rear PTO only.
I expect I will need the driving mechanism too. Do you have that by any chance also?
At any rate, I will be waiting for your reply as to if this is still available.
What state are you in by the way? I'm in NJ, heading to PA ASAP.
Thanks for your time, Dirtndents.
Dirtndents
Kubota B7200D
Oct 26, 2025
Dirtndents
Kubota B7200D
Oct 26, 2025
Gunnerdog1,
I just wanted to let you know I will be on the road as of Wed. morning, 10/29/25.
If you reply to my post I won't get it for about a week.
I am interested in contacting you however.
Hopefully for the benefit of both of us, we will finally connect, and your parts can get to a new home.
I just found out by chance, that a profile shows up when you hover a second over the name, and I see you are in Owego NY. You are closer than I figured you would probably be to me in central NJ. That could be helpful.
Thanks, Dirtndents.
Mrlunchbox
2023 BX2380 loader/mower. Land Pride snow pusher, Kapteyn pallet forks
Nov 21, 2020
406
179
Southern Worcester County, MA
Gunnerdog1,
Thanks, Dirtndents.
Try sending a PM. Might get a response from that
gunnerdog1
B7200
Feb 19, 2015
Owego, ny
Gunnerdog1,
Thanks, Dirtndents.
Dirtndents
Kubota B7200D
Oct 26, 2025
Greetings MrLunchbox,
Thank you for taking the time to make that suggestion to me. I do appreciate that.
As it turns out, I just got back today and have been going over my unopened inbox emails.
I saw yours first, and was going to act on it after I plowed through the rest of the 350 emails I got.
On the next page or so was a reply from gunnerdog1, and so I have now heard back from him.
Again, I Thank You for your suggestion!
Cheers, Dirtndents
Dirtndents
Kubota B7200D
Oct 26, 2025
Hi Dale,
I just sent you a post to your PM.
Having communication problems with the phone number for some reason. Let me know, as I tried calling you today.
Looking forward to talking with you.
Thanks, Chris
11,319
You do realize this deck is for a Mid PTO tractor and will not work on a front PTO kit.
Dirtndents
Kubota B7200D
Oct 26, 2025
Greeting N.I. Wolfman,
To answer your question simply, No.
I have no specifics of any kind as to the configuration of this deck, other than mounting points.
And this is why I have been trying to get in contact with gunnerdog1, to find out what he can tell me from his hands-on use of it.
There is an proliferation of RC60-___ (fill in the blank) application types, as there are for the other mower base models.
There is Not however, a 'proliferation' of information describing the details of those fill-in-the-blank details, although I have spent some time now doing searches to try and come up with something.
I have found some of course, but not enough to get a definitive idea.
These implements seem to follow the same numbering system/I.D. type as Weber carbs and Military vehicles....basically arbitrary. I write that statement from much experience with both equipment types.
That would be OK, as long as explanatory info could be gotten ahold of.
As to our 'new' Kubota, it is equipped with a rear PTO only. I have as of yet to find the mechanical details of the layout of a mid-mount PTO, let alone its availability, whether or not it could even be mounted on our B7200 D geared-trans-tractor, and the all-important cost.
Any info would of course be appreciated.
As such, I appreciate your question, both as a heads up, and as an introduction to the larger questions.
Thank you for taking your time to do so.
11,319
You can tell by the layout of the PTO shaft off the gear case (in his pictures) that its a Mid PTO model (RC60-B) and not a front PTO model (RC60-72).
You can not add a Mid PTO to a B7200D tractor, you would need a B7200HSTD to have the mid PTO availability.
In addition to a front PTO deck you would need the front PTO drive which is rare and hard to find a complete setup:
Below are three sets of parts needed to makeup the front PTO drive.
Dirtndents
Kubota B7200D
Oct 26, 2025
N.I. Wolfman,
That is quite an edification!
Thank you so very much.
That was EXACTLY the type of information I have been searching for, and you provided it all in one place!
It is unfortunate that gunnerdog1's mower deck is not the type that I need to attach to my machine.
RATS!
I will have to convey that to him ASAP.
It IS good to know where I stand however, and once again, I certainly appreciate it.
Now to start looking, as I have many times for my older vehicles and equipment, for those not so common parts.
Cheers!
