Kubota B2400 - Oil drain plug directly above loader bracket??
mikebpbx
Kubota B2100 w/ RC60-24B deck and bagger
Jul 12, 2024
15
Eastern NC
Y'all:
I am attempting to change my oil and the dang oil drain plug is directly above a welded plate for the loader bracket.
Does anyone have a similar setup and how do you change the oil? Just open it and make a mess or what? I'm not removing the loader mounting bracket, that's for sure. This is a dumb-assed design.
Sawdust&Shavings
Apr 25, 2023
104
97
Stafford, VA
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,640
1,923
Near Lancaster, PA, USA
Often a piece of cardboard, scrap piece of sheet metal, cutoff plastic bottle, etc works fine. It looks like the MMM isn't doing any favors.
5,395
Y'all:
In cases like that I would stick a drain pan under it and "make a mess". I have seen far worse..
5,728
keep the oil FILLER cap ON until AFTER you remove the drain plug.
I do that on my BX23S and oil slowly 'plops' out, giving me more time to adjust the drain pan. THEN I remove the filler cap...whoosh.....
BTW '97 F150 4.6 has similar 'location' issues..... for the oil filter.......
