ZD326 Frozen Scalp Wheel Shaft Troubles
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
My point being that if Mr. Haney sees and criticizes an example of what he believes is poor-engineering…. Unless the product was engineered by Russell himself…. then the criticism shouldn’t offend.
I agree.
Everyone who is blaming the consumer for this is not just wrong, but absurdly so, not to mention (determinedly) confused about the difference between grease and anti-seize. They are completely different products, and grease is NOT NOT NOT anti-seize and will NOT perform the same function as well.
Saying grease is the tool for preventing rust seizing is like calling WD-40 a lubricant, which, unfortunately, is something a lot of people do. Anyone who has made the grease mistake may be helped by this information before it's too late.
Also, there are different types of anti-seize for this application. You want copper here, not nickel.
In case anyone is interested, I was wrong to call the problem with my mower "galling." I have learned that galling only happens with moving parts, and a shaft you move once a year or less is not a moving part. The proper term is "corrosion-induced adhesion," or you can just say "rust seizing."
It is also unfortunate to see that the turning front wheels are still being deliberately conflated with the non-turning rear wheels, even after painstaking and patient correction. The guy who bought the mower new screwed up the front wheels by ignoring the manual, but the manual does not mention maintenance for the rear wheel shafts, and the shafts, which are not moving parts, have no zerks or journals.
Hugo already knows these are different parts, and he has been told the manual does not mention greasing the rear wheels, which is the wrong remedy anyway. This has already been explained, so I don't think he should keep circling back as though it there were still some valid point to be made. I hope we don't have to beat this very dead horse again.
My bet: we will soon hear familiar hoofbeats.
As mentioned several times, JD makes a similar assembly with much looser shafts, and my JD wheels are about 35 years old with zero issues and no real maintenance. No greasing, anti-seize, or periodic disassembly.
Kubota had no excuse for doing it wrong, especially 25 years after JD, a feared competitor, made my JD deck. You don't sit back for 25 years and watch your competitors do smart things while you repeat the same obvious mistakes. Kubota pays people a lot of money to keep up with John Deere's doings. I don't have to email them and ask. Every competent big company watches the competition carefully.
Being too lazy to go outside and measure, I would guess the clearance on the JD is around 0.050" (radius, not diameter), so the shafts are very loose. And in perfect condition, on a mower that has seen lots of hard use. JD's design allows the adjustment pins to wear from the movement of the shafts, but the expensive shafts don't weld themselves to the deck, and they have not worn out.
Let me put it this way: if you remove the pins from a JD shaft after 35 years with no maintenance, it FALLS OUT.
No hydraulic press needed.
The JD design works perfectly because 1) the gap allows water to drain out so the parts can dry, 2) the parts can move a little, beating up any rust that tries to develop, and 3) the parts would have to have a gigantic layer of rust between them in order to seize together, and a layer like that can't form.
I am not a JD fan, but they were right about this.
For anyone who is interested in the solution to the anti-scalp wheel problem instead of the cause, which is obvious, a progress report. I solved the problem.
Drilling out the left-hand wheel shaft was not smart, although it was smarter than designing anti-scalp wheel shafts that cement themselves to decks. It took forever, and all it did was help me avoid a little cutting and welding, which is easier work.
Today, I cut the right-hand wheel support off the deck and put it in the 20-ton hydraulic press. I thought I would have to make a jig to hold the support, but--and this is good information for others who have this problem--a large impact socket will work just fine. I supported the part with a socket, and it did the job. You can only push the shaft so far, however, because the ratchet end of the socket is obstructed, so using a proper jig is better.
I thought using the socket would be easier than cutting metal stock and drilling it, but if I had had a nice piece of round steel bar, I would have used machine tools to make a jig.
Fortunately, my press is air-over-hydraulic, because I had to reverse the part maybe 20 times. The shaft was in there so tightly due to Kubota's booboo, the press did not knock it loose right away, and the shaft did not want to go very far before slowing down the press. On the first try, the shaft moved about 3/32", and over time, it got looser and moved farther.
I kept turning it and applying Deep Creep, and I cleaned it occasionally. Eventually, I got it to the point where it would move on the 3-ton arbor press, which is quicker to operate.
Having turned it maybe 15 times on the arbor press as well as wire-wheeling the exposed parts of the shaft with my industrial pedestal buffer, I got it to where I could move it by supporting the assembly in a vise and using a blacksmith's hammer and a punch. Turning it and whacking it over and over, I loosened it to the point where it finally fell out.
Let me illustrate just how bad Kubota's design is. I sanded the inside of the support, and I wire-wheeled the whole shaft and also made sure there were no burrs. It is STILL a tight slip fit, even with the plating worn down.
For those who don't know, a slip fit is a fit that is just loose enough not to be an interference fit or transition fit. An interference fit requires force because the internal part is actually larger than the ID of the external part. A transition fit is what you get when a shaft is the same size as a hole.
As proven above over and over, and by a bazillion John Deeres with shafts that didn't seize, a tight slip fit is totally unnecessary and inappropriate here. It means the part will start to stick the very instant it begins to rust, and rust is guaranteed in a carbon steel part in my particular climate, even indoors. Rust takes up more room than sound metal, so when an enclosed part rusts, the fit gets tighter. It's like the inner part is water freezing in a sealed pipe.
When you leave no room for expansion, like Kubota, any rust will lead to immense pressure, friction, and then seizing. As you can tell from my description, in this case, the seizing was too strong for tools like a sledge, a torch, and a three-foot pipe wrench. It was no joke. This shaft was fixed more stubbornly than typical press-fit shafts. A sledge will knock a pressed shaft out.
By the way, the reason heat works to release (some) rusted parts is that the heat expands both the inner and outer parts, crushing the rust between them and weakening the bond. This is why heat often works all by itself, even though you would expect to have to cool the inner part. A lot of people think you always have to cool the inner part, but that isn't true.
Not only did Kubota make the fit too tight; they put the wrong types of metal together. Kubota plated the shaft with a weak and ineffective layer of cadmium or something, but they left the plain old carbon steel of the tubing alone, just waiting for the inevitable condensation to creep down into it. Then they failed to mention maintenance in the manual.
They could have pressed a brass sleeve into the bore, not that this would be as good as simply making the shaft the correct size.
Cutting the support off was the way to go. There was no way to make this shaft come out without drilling it, using something like EDM or a cutting torch, or pressing it out. Pressing is easiest, and you can't do it with the part still on the mower unless you design a special tool. Three tons of pressure from the arbor press didn't faze it. I don't know if a 12-ton press would have worked. Twenty tons got it done.
I considered rigging up a large pulley puller to push it, but I suspected, correctly, that it would never provide enough force.
Now I just have to deburr and clean everything, weld the support back on, and prime and paint. If I can find an easy way to hold it in the mill, I may also open the tube up by maybe 0.020" to correct Kubota's obvious error.
For others who face this later, I used a 6" grinder with a Walter cutoff wheel, a cordless sawzall with a thin-metal blade I shortened, and an oscillating tool with these carbide blades I heard about from Project Farm: https://www.amazon.com/dp/B07YDMX328?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
I also played around with a Dremel and a hacksaw, but the above tools worked best. The carbide blades are a thousand times as good as the Ridgid blades I bought in the past.
Today or tomorrow, I'll prep the part and the mower for welding and painting, and then I'll put the other new parts on the mower, including the sun-damaged fender I broke with my genius method of removing it without taking the step off. By Monday, I should have a functional mower with 4 anti-scalp wheels.
25 08 21 kubota mower anti scalp wheel support off mower next to removed shaft small.jpg
5,774
GREAT writeup, kinda surprised a zillion 'whatweretheythinkingofSOB ' blows didn't pop the pin out ! BTDT. Have always said that 'engineers' need to work on whatever they 'engineered' in t eh REAL World, then FIX them using NORMAL tools.
I'd expect those pins to be 'sloppy', like you said, 'big' gap gets rid of water as well as dirt, grass clippings, etc.
Probably rain on Monday, hehehe.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
Wow! Someone agreed with me about something and didn't get mad at me! Thank you!
Another source I consulted mentioned dirt and grass clippings as things that would call for a looser fit, so you are a good engineer.
The new shafts look to be chrome-plated. I hear cadmium fell out of favor due to toxicity or something. The old ones were made more carefully. I guess the new ones are Chinese.
I am tempted to make them thinner and have a chrome shop go back over them.
Here is a photo of an anti-scalp wheel shaft that was designed correctly:
3,636
I agree.
I DO have one small question, Mr. Haney…. When you wrote “I hope we don't have to beat this very dead horse again.
My bet: we will soon hear familiar hoofbeats.”
Exactly How does a dead-horse make hoofbeats…? LOL
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
Today I cleaned everything up for welding, and then I put the support back on the mower. I attach a photo. I put the new wheel shaft or pin, or whatever Kubota calls it, in the photo so people can see what a great job Kubota did with the chrome plating. It's already coming off in many places, so rust started undermining it in the factory, which I assume is in China or India.
Kubota used excellent paint. It's very hard to remove for welding, so I ended up using a knot wheel and a stripping wheel with angle grinders. A wire wheel did almost nothing, and sandpaper was useless.
I had a catch-22 situation here. This job would have been much easier had I taken the deck off the mower, but the removal process involves turning the anti-scalp wheels. That was not possible because of Kubota's mistake. With the deck on the mower, it was hard to cut, grind, and weld. I had very little room, and I could not see well.
Now I have it attached the support well enough to allow me to install the wheels and remove the deck, so I can go back in and do a nice job of fixing up the joints and painting. Unfortunately, I still need to put the new fenders on and replace the left tank and step mats before it will be convenient to start the mower.
The newer ZD1211's 60" deck has a completely different rear wheel assembly, suggesting Kubota got tired of seeing people on the Internet complaining about this issue. It is not confined to zero-turns or the ZD326. A lot of people have had this problem.
5,774
Hay I'm not going to get mad at you , even when you 'insult me for being an engineer' ! lol,hehehe.
In 5 decades I've only dealt with ONE engineer ( guy has PHD, Electrical ) that actually would LISTEN to what I had to say about problems HE was having. Considering he helped design the shuttle's Canadarm, he was always open to my comments, especially when I increased his bottom line by about 15%.
While the wallpaper says I'm and Avionics Technician,put 11 years in in spectrometers/mini computers, then design/build remote energy control systems, and of course several '67 Mustangs,real JEEPS and a 12 speed Willys pickup. A LOT of learn by doing of course. I applaud everyone that gets their hands dirty and FIXES stuff.
As for the mower 'deckon-deckoff' pain... consider making/installing a 'gantry crane'. Mine's a 4b8 steel I-beam across the 24' wide garage. 2 chains hoists on trolleys allowed me to safely split the A-C D-14 several times. it's great to raise up the front of 'riders' to clean decks, change belts, r/r blades. Also use it to flip over 5by8 utility trailers that I make.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
I like to think I will never have to take the deck off without wheels. If that happens, spending $18000 on a new mower will look cheap.
Information for anyone installing new fenders: first, don't break them like I did. After that, you need to know that each fender has 4 black nylon inserts that hold the Phillips screws that secure the fender. Of course, Kubota does not include these with the fender. Amazing, but true. Try and imagine a world in which someone would need the fender but not the inserts.
The inserts are made so two little protrusions pop up after insertion and anchor them in the fenders. Very, very difficult to make them back out. Like 20 minutes each, and I had to use hose grip pliers.
I did two the hard way, and then I realized the obvious: the fender cracked because it was brittle, so that meant I could break the fender without hurting the inserts.
You put the little plastic screw well that holds the insert in a vise or something similar, crank it down, and the plastic explodes, leaving the insert unharmed.
The part is called a Kubota nut, and Coleman's charges $3.49 for one, so about $28 for two fenders.
William1
BX25D
Jul 28, 2015
1,243
440
Richmond, Virginia
My own experience with 'frozen shafts'. I put what ever it is in a big press, properly block it. Press. 30 tons will move just about anything. Just be prepared for the giant terrifying "BANG' when the bond breaks loose.
Like a lot of jobs, prep is 99% of the job and if done with thought, the actual job is easy. I'll often make a jog to do repetitive tasks as the time spent making the jog makes the entire job go quicker.
As to the original issue, yeah, zerks and hopefully they get used.
Show me a lever long enough and I can move a mountain.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
I heard that BANG, for sure.
Interesting fact about Kubota's lame design: plating the pins did absolutely nothing to prevent seizing. The bores are not plated, so rust will continue for the life of the mower, and even a tiny bit of rust will cause seizure.
The plating is just for looks, which is sad, because the plating on my new pins has big, rusty holes in it.
Reducing the diameter of the pins is the best long-term solution. Coming up with a new assembly with bearings would be neat, but in practical terms, it would be inferior to just trimming the pins.
Someone suggested plating them with copper after I trim them down. That would be easy, since I have the right chemical on hand for other purposes. That would look better than rust. I think zinc is the final solution, since I don't want to mess with chrome at my house, and the nearest chrome joint is far away. Zinc isn't all that tough, but it would be easy to redo.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
Here's some great news. Coleman's ships fenders covered with adhesive bubble wrap. Maybe they come that way from Kubota. This stuff takes several minutes to tear off, and it leaves an adhesive residue on the plastic. So now the 30-second job of unwrapping the fenders is looking more like 60 minutes including finding a solution and cleaning both fenders.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
It is amazing that intelligent people would ship a product covered with adhesive.
The answer is turpentine. Alcohol works slowly. Goo-gone does very little, which means WD-40 and mineral spirits will work slowly. Lighter fluid is better than alchohol and Goo-gone. Turpentine works fastest and best.
Acetone will eat the fender, so I guess Kubota is not using a high grade of plastic.
I would stay away from alcohol because acetone and other solvents that are added to it could eat the plastic.
So this kills a day of repair. I have to clean both fenders, let them dry, and clean them again. When you do the first cleaning, you end up with diluted adhesive on your paper towels or rags, so that's what you leave on the fender. You need another cleaning to get it all off.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
Turned out the turpentine dried faster than I thought, so the whole ordeal lasted less than an hour. The fenders appear to be okay. Thanks to the turpentine, my house smells like Paul Bunyan's armpit.
Kubota is the culprit. Their sticker is right on the bubble wrap. I thought I had seen some stupidity already, but this is a new low.
3,636
Kubota is probably tired of all the whiner’s complaints about paint. “It’s faded” “it’s dull” “it’s scratched”…. on TRACTORS for Keerist’s Sake!
So for You…they protected it with strong, protective plastic-wrap.….
Now Kubota can listen to complaints about their protective-packaging. :sneaky:
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
Normal bubble wrap and two pieces of tape would have worked perfectly.
William1
BX25D
Jul 28, 2015
1,243
440
Richmond, Virginia
Thin bronze bushings?
3,249
1,675
All of Kubota's body parts are shipped that way. The bubble wrap has a very weak adhesive that washes off easily with a mild soap and water. This has been their standard for many years.
I replace probably 8 L01 series hoods a year; it takes all of 5 minutes to unbox the part, remove the bubble wrap, and wash with soap and water if necessary. We wash them before installing decals.
I installed a set of ZD1211 fenders a month ago, took 3 minutes or so to unpack and remove the wrap.
The wrap sticks to plastic a little better than it does painted metal.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
That is amazing. It's a good thing you posted that, because finding the information with a search engine was pretty much impossible before today.
I was not able to unwrap these quickly The bond was very strong. I could have broken the fenders if I had tried to work faster. I would guess this stuff sticks more tightly the longer it sits in a warehouse.
Water was the first thing I tried. I thought surely Kubota didn't expect customers to put solvents on plastic. It did just about nothing, so I had no reason to think soap and water would be much better. The general rule in life is that soap and water are useless against adhesives. I have to wonder if the glue on my fenders was stubborn because it had dried out over a decade or more.
I searched for the answer to this problem yesterday, and I made an AI bot search repeatedly. No help at all came up. If Kubota insists on using this glue, they should put some kind of note on the product label.
Two pieces of tape and a sheet of normal wrap would have worked just fine. I wish they had done it that way. I have bought an enormous number of products over the web during last 25 years, and I have never seen anything like this before.
I guess Kubota doesn't think about the fact that some people have to pay employees for the time involved in unwrapping, washing, and drying, which are unnecessary for other companies' products.
Mr Haney
L3710, ZD326S
May 23, 2022
369
94
FL
I mowed yesterday.
The anti-scalp wheels are not finished, but the yard was a foot tall, and I refuse to use the John Deere, so I did what I had to do. I ran it with one old fender and one new one. I still have to do the final grinding, welding, and painting on the deck's right rear wheel.
The crucial stuff will be fixed shortly. Other things can wait for cool weather so I'm not pressured to mow every weekend, and I'm not sweating into my glasses and sticking to my shirt while I work.
Next week, I plan to put the pins on the lathe and trim them down so they can never seize again. This will remove a lot of the low-quality chrome, so I may take some copper sulfate and a battery charger and see if I can plate them. Better than nothing. I am tempted to look into Cerakote. Paint would discourage pin rust well enough. It works for John Deere.
The horizontal adjustment pins are also too tight and subject to seizure, so I will be pitching the Kubota pins and looking for thinner ones. I'm sure someone makes them, or I can find bolts I can cut to size and drill for R-clips.
I am thinking of throwing out the Kubota-style push rivets I bought and buying a smarter type which can be removed with a screwdriver. There was a ton of sand under the step mat, and I would like to be able to clean the step off a couple of times a year. My tractor's mat has no push rivets, and it works perfectly, so I think push rivets were a bad idea from the start. I can pull my tractor's mat up in a minute or so.
The left tank is clean, as are the fuel lines. The filters are okay. I still had some stalling when running on the left tank. On a whim, I switched fuel caps, and after that, the mower ran well regardless of the selector position. I don't really understand that. I would expect a bad cap to cause problems on either tank.
Kubota has discontinued the original cap, but it looks like a cap made later will fit. I think the cheapest price I saw was around $28, so it must be a very, very nice fuel cap. I am going to take the one I have and see if I can do anything to make it work. I'm wondering if I should buy a couple of spares, since I plan to keep this mower as long as possible. Kubota's unpredictable parts support appears to be the limiting factor, so I think I should try to identify important parts that I may need in 2035 and buy them now.
The mower is a joy to use when it works. Mulches like crazy and cuts better than the John Deere. Seems like it mows twice as fast. I can see why zero-turns were invented. The dedicated design is far superior to a tractor with a belly deck.
I have learned that zero-turns really accumulate crud. Much more than tractors. There is still stuff in there from the Obama years. I run a leaf blower when I get off the mower.
I think I should look into a flap that closes the chute. I like the way the mower blows debris off to the right, but sometimes it necessitates looping around so the chute points away from the house and so on. There is a little damage to the skirt at the rear of the chute, but I can fab up a piece of steel and weld it in there so it's as good or better than new.
If I have a flap, I'll be able to keep it closed most of the time and use the mower to move debris the rest of the time.
I will continue improving on Kubota's design for as long as the mower is viable. I can't help wishing I had spent $18,000 on a ZD1211, but once the pain of getting this thing working is over, improving it should be enjoyable. It's a great product apart from a few unfortunate bugs.
