New LX2620 Driveshaft rattle?
Andyshine77
LX2620
Apr 20, 2025
Cincinnati Ohio
Just a quick question. I have a very new LX2620 with 21 hours on the clock.
The main driveshaft off of the engine is producing a rattle/knocking noise, especially at lower RPM, idle and when you first press on the hydrostatic pedal to move either forward or reverse. I removed the plastic cover and inspected the shaft and coupler. The shaft has plenty of horizontal movement, which is normal, there does not seem to be any radial play. Is this sound normal or common noise?
I know it's a tractor with a three cylinder, so it's going to have some oddities with the 120° firing order, it's not a Cadillac. It just seem slightly odd on new piece of equipment, that and I don't remember the same type of noise on the old b8200, but then again everything on that tractor rattled.😄
It's probably normal, just thought I'd check in here. Other than that I'm in love with the thing and it runs flawlessly otherwise.
BAP
Dec 31, 2012
3,001
1,103
At 21 hours, I would be talking to your dealer about it and not spending much time investigating it yourself. Unless you have aged out of your warranty you definitely have less than the hours that the warranty is good for.
Andyshine77
LX2620
Apr 20, 2025
Cincinnati Ohio
I bought it this past May so it's still under warranty, I'm not worried about that. I wanted to know if it was normal so I don't waste my time or the dealers. I'm learning towards it being normal, but I'm not positive.
Andyshine77
LX2620
Apr 20, 2025
Cincinnati Ohio
There's a plastic cover on the floor over the shaft and transmission between your feet. It partially exposes the end of the shaft at the transmission, that is where the rattle is.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
Is your LX2620 a cab model?
If so. I will go take a look at my LX2610 Cab and pull that cover and see if mine sounds the same.
I haven't heard anything like that sound from my tractor. But I haven't had the floor cover off before.
I would guess , a big guess... from Wolfman's post there may be a missing part #100, or maybe two. Which appears to be a compression o-ring to keep the balls in the CV joint from rattling.
Sorry, a shot in the dark.
Andyshine77
LX2620
Apr 20, 2025
Cincinnati Ohio
Non cab model. You can hear it with the cover on.
I'd really appreciate if you checked to see it's super easy to take the cover off if you want to.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
I'll look into it. The floor might be different in a cab model.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
This afternoon, I will be schooling / training my wife on the use of the rear pto and the rotary cutter.
I should have an answer for you in a few hours.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
No sound like yours has on my 2610.
But, My wife did great today... her first time using PTO and the rotary cutter.
IMO. Take your LX2620 to the dealer for warranty fix.
Good luck Sir or Maam.
Old Machinist
May 27, 2024
457
495
NE FL
Good luck getting your tractor back. I let my wife drive mine and she decided I could get back on the old open station JD and mow while she sat in the AC and "HELPED". I finally convinced her I didn't need her "HELP". LOL
Old Machinist
May 27, 2024
457
495
NE FL
My LX3310 had a horrendous vibration at the extendable links on the 3 point. I removed the ends and wrapped the arms with duct tape. Put the ends back on and it was gone. It probably wouldn't have made it with something attached but it bugged me enough to try and solve it before using it.
It still has a vibration at the grill guard I haven't tried to solve yet. I only hear that one when I'm standing in front of the tractor. The hitch vibration would run you out of the cab.
Andyshine77
LX2620
Apr 20, 2025
Cincinnati Ohio
So how would in go about removing the coupler on the shaft to inspect the internalcomponents? I see the Roll pen will have to be punched out.
BAP
Dec 31, 2012
3,001
1,103
Your tractor, but I would be careful about taking too much stuff apart on your new tractor looking for a problem, then expecting a dealer to repair it on warranty if you do find a problem. If they find evidence that you had it apart they could deny warranty and blame you for causing the problem.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
^^^^^ That^^^^
Sometimes with new toys we are overly concerned. I honestly don't think there is an issue with your new tractor.
Talk to the dealer and make a notation that you did. If he says bring it in, do it.
Otherwise, just use the tractor and have fun.
Either way, relax. And don't start tearing it apart looking for what may be a non-issue.
Be well. Tractor on.
Eric
9,144
You have to split the tractor to inspect or replace any of those parts.
