M5640 Hydraulic Filter usage
DavidL12
M5640SUD
Aug 18, 2025
Warren, PA
I have a M5640 and was replacing the two hydraulic filters and noticed that the forward most filter did not have anywhere near the same amount of fluid inside when i removed it peeked my curiosity. I looked in the manual and Workshop manual and i could not anything that identifies what hydraulic functions are supported by each filter, the workshop manual has a flow diagram the show the filters plumbed in parallel but nothing else.
All of the hydraluic functions on the tractor (including loader and backhoe) work fine, i am just curious what functions each filter supports.
R/
3,285
1,902
R/
Those are suction filters, piped in parallel so they both serve all functions. Two filters are required for the higher flow rate.
g_man
Feb 3, 2023
247
1,126
NE Vermont
R/
I would think that it is likely that when you removed the first filter it allowed the second filter to partially drain thru the open fitting.
DavidL12
M5640SUD
Aug 18, 2025
Warren, PA
G-man, Thanks for the info, after PoTreeBoy's response i had the same thought as yours. I was just surprised at filtes being piped in parallel.
