L4310 only steers one way?
Hprb
L4310
Aug 17, 2025
Hawaii
Hello,
I have a L4310 and I took off the steering ram as it was leaking. Took it to the shop to get it repaired, reinstalled and tested. Now if I jack up the front and turn the wheel it can go way way too far to the right and barely anything to the left. Any thoughts? The ram shaft end is fixed on front of frame and the ram body is fixed in the horizontal part of pitman arm so I’m at a loss. Additionally ram body seems to “lift up” even though I reinstalled everything.
thanks!
Holokai
9,171
Pull the lines off of the cylinder, put them in a bucket, slowly turn the steering each direction.
Do you get the same flow out of each line?
Does the steering feel the same each direction?
If you do you have a fitting issue or a rebuild cylinder issue.
If you don't get flow or the same feel then you have a controller issue.
Was the initial issue only a leak as to why you pulled the cylinder?
If it was only due to a leak, then it's most likely they messed up the cylinder rebuild!
But the cylinder should not move up and down when it works, so that doesn't sound right either.
Hprb
L4310
Aug 17, 2025
Hawaii
thanks for replying!
I’ll do those tests, the issue is then the steering wheel is all the way left the wheels are lightly left and the cylinder is maxed out. When I turn it right it goes way too far until the cylinder is maxed out. Sorry not sure if that clarify?
9,171
With the lines off the cylinder and the front tires lifted off the ground.
See if you can manually turn the tires side to side.
Hprb
L4310
Aug 17, 2025
Hawaii
Ok,
Front jacked up and lines off it still has the same range of motion. Barely to the left and waaay too far to the right
ruger1980
L4310 w/La682, L225
Oct 25, 2020
520
206
CNY
Did the shop possible assemble the steering cylinder with the barrel reversed?
9,171
Ok,
Yep, sadly it sounds like the cylinder has not been rebuilt properly.
You might still want to double check that you've installed everything correctly.
Hprb
L4310
Aug 17, 2025
Hawaii
Ahh I think that is correct. Arrrghh! Haha, guess I have to take it apart and back to the shop. Thanks everyone who helped. I’ll update after taking to the shop!
PaulL
2,619
1,589
NZ
It's not possible to install the cylinder reversed or something? I always look for a way I could have screwed it up before I assume that someone who does it for a living might have screwed up. Not that they don't screw up, but it's less embarrassing if I start by assuming it was me somehow, then if it turns out it was me, I'm not surprised. :)
Hprb
L4310
Aug 17, 2025
Hawaii
No, it only has the frame mount on one end. If possible I would have screwed it up but in this case I didn’t really have a chance haha
QUOTE="PaulL, post: 809293, member: 32061"]
[/QUOTE]
