B2650 5amp OPC/Panel keeps blowing
Pavedog
B2650 LA534
Jan 23, 2019
FAIRFAX STATION
I have a 2016 B2650 and has worked terrific until a couple weeks ago. I went to start it and the screen went blank and it would not start. I replaced the fuse(with the seat up) and it would start. However, when I put the seat down it immediately blew the same fuse and shut down. I unhooked the plug for the seat and it would allow me to move forward but of course because it doesn't detect a driver it shuts down. Looking at schematics online I am unsure of which of the safety switches I should focus on and how to test it beyond what I have done.
Hugo Habicht
G1900
Jun 24, 2024
932
1,311
Ireland
Hello,
I had the same problem recently on an L1 tractor. From what you describe it is the seat switch the reason for the fuse blowing. It shorts one pin to ground (tractor chassis) when putting down or sitting on the seat.
I'd suggest you try to take the seat switch off and see where the short circuit is, could also be in the switch wiring. I have not done that, otherwise I could send you pictures what it looks like.
For testing (!) you could disconnect the seat switch and short the bridge the connector pins on the tractor wire harness side with a thin solid wire. If tractor runs fine then this is the fault.
Hugo Habicht
G1900
Jun 24, 2024
932
1,311
Ireland
Here is part of the schematics. You find the complete work shop manual with schematics on kubotabooks.com for download.
The seat switch is supplied through the fuse (red) and so is the instrument panel. Switch output goes to controller then (yellow). When you put the seat down the cable to the seat switch shorts to chassis / ground and blows the fuse.
Check where the cable is squeezed, repair it and possibly reroute or attach with cable ties that this cannot happen again.
Good luck with the repair !
9,486
@Hugo Habicht
Where did you get that schematic?
It's not a B2650, caught that right away because a B2650 does not have bi speed turn.
Same concept just the right schematic. ;)
nbryan
Jan 3, 2019
1,345
875
Hadashville, Manitoba, Canada
I loosely tied my B2650HSD seat switch lever in the down position with a loop of zip tie. Against the safety rules but a recent back surgery has left me unable to sit for more than a minute or so before the pain is too much.
So until I heal any work is done with me standing. Moving wood crates with pallet forks and some 3-point rotary mower work, short stints, that's it for now.
9,486
I had picked the ROPS version schematic
Yea sorry wrong tractor, that's the EU version, they are really not the same tractor as the US version.
I know stupid confusing.
I didn't make their number system up, I just know how to follow it.
Hugo Habicht
G1900
Jun 24, 2024
932
1,311
Ireland
Can you enlighten me how to distinguish the US from the EU work shop manuals? I had a look through it but did not see anything obvious.
9,486
First it lists models that were not offered in the US.
B2050,B2350,B3150
Second it has ROPS designs that are not available on the US models.
It has other options that are not available on the US models, like bi speed turn.
And when all else fails look up the Manual part number:
This manuals part number (last page): 9Y111-09820
The right manual for the US mode B2650: 9Y111-08222
So yea, not anything that's easy and obvious to figure out the difference.
Pavedog
B2650 LA534
Jan 23, 2019
FAIRFAX STATION
When I had this problem it was an intermittent short in the neutral safety switch
Was there a way to test that? I disconnected the seat switch, it no longer blows the 5amp fuse, but without it hooked up I can't operate the tractor. When the switch is in the circuit it will blow the fuse every time. I realize that can also be a problem with the OCP, so just trying to troubleshoot which it is. Where on the 2650 is the neutral safety switch?
Thanks for your help
Dustball
2016 B2650HSDC
Sep 15, 2023
446
307
Hudson, WI
You've already pinpointed the issue- it's the seat switch circuit. Either the seat switch itself is bad or you have a short to ground between the seat switch and the OPC controller. If you want to isolate whether it's the switch itself or not, disconnect the seat switch connector and jumper the two terminals together on the tractor connector. If you're able to run afterwards, it was the seat switch. If it still blows a fuse with the connector terminals jumpered and the seat switch disconnected, it's a wiring issue.
5,978
You have a bad neutral safety switch. Had the same issue on mine blowing OPC fuse. $50 later, problem fixed.
The neutral switch (HST switch) isn't too bad to replace unless you have a backhoe. Support frame makes it tricky to get in there to replace it.
Pavedog
B2650 LA534
Jan 23, 2019
FAIRFAX STATION
I will try the jumper. I assume besides a ground issue it could also be the OPC module too?
Pavedog
B2650 LA534
Jan 23, 2019
FAIRFAX STATION
I will look at the neutral safety switch too. I assume I can remove it and test it to check if it is able to close and open and not short.
5,978
see here and the very next post by hugo.
When I bench tested my bad switch, it appeared to be fine...but I can tell you that in the field it was not. Perhaps yours is just out of adjustment.
Hugo Habicht
G1900
Jun 24, 2024
932
1,311
Ireland
You put down the seat, the fuse blows. Check the seat switch cable or disconnect the switch and jumper the connector. That's it.
