Bx2380 steering issue
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
Starting around 75 hours I started to have an issue with my steering. Turning the wheel it would make a thump feel and you could see the front tires jerk when it was either turned around the 10 o'clock or 2 o'clock position. Also if you turned the steering wheel in either direction slowly the wheels wouldn't move unless it was turned fast. This would happen when the tractor has been running for a least an hour and a half getting the fluid nice and warm. Took it to the dealer at 100 hours and they determined it was the steering valve below the steering wheel. They replaced it and was fine for three weeks and today it's back doing the same thing but also now has a squeal/wine sound around 90% turn of the steering wheel left or right and can feel both hoses going to the front steering cylinder vibrate when it squeals/wines. Fluid level is full. I'm really scratching my head on this one. Any ideas? I'm wondering if a clogged hydraulic filter would cause this but have no other hydraulic issues. Filter was changed at 50 hours. Like I mentioned above, it really seems to show when the fluid is hot like when I've been mowing for awhile. Also today when I was mowing I was turning the steering wheel at a normal speed and a few times the tires didn't turn.
9,138
How many hours total are on the tractor.
When was the last time the filter screen was cleaned?
Try moving the three point lever when your having steering issues and see how it reacts.
Does it have a loader?
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
115hrs. Filter screen hasn't been cleaned as of yet. Only new filter installed at 50 hours. Was going to do a fluid change next month even though the manual says 300 hours. It does have a loader. Only test I could try moving the 3 point would be when I turn the steering wheel slowly without the wheels moving because the sequel/whine happens quickly but I can't keep it at one spot where it's constant. The strange thing is the problem went away after they replaced the steering valve and has been fine for three weeks until today. Wonder if the valve they replaced could be defective.
3,247
1,675
Your dealership must be inexperienced with the BX series tractors; your problem is that the steering cylinder needs to be replaced.
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
That was what I mentioned to them it might be that the first time last month. Strange it would fail with the low hours. But they said it was ok and the steering valve needed replacement. If it truly is bad why was everything fine for three weeks and all of a sudden today it's doing the same thing. Loader, 3 point and hst work fine.
3,247
1,675
Yes, I have found a few that failed at low hours.
If you can turn the steering wheel slowly and the wheels do not turn, the cylinder has failed 99.99% of the time.
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
@whitetiger Thank you for your knowledge and help. I mentioned that like I said the first time to the dealer and he said it does sound like that's the issue as well until his tech looked at it. He also said that we rebuild them which I was wondering if that's what they do for warranty instead of installing a new one?
Spam Bot
Windows Computer
Aug 3, 2024
76
46
Austin, Minnesota
Rebuilding is only as good as the person doing the rebuild. If it is close to being out of warranty, insist that they replace not rebuild.
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
We replace them under warranty.
@whitetiger . First thank you for your expertise. They picked up my tractor today and are going to replace the cylinder and not rebuild it. One question though. The problem shows it's face when I have been working the tractor for awhile. Like mowing and heating up the fluid. Is this because the fluid gets thinner when hot and makes it easier to bypass the cylinder seal?
3,247
1,675
That is very likely the case.
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
Dealer said cylinder tested fine. They got the tractor to duplicate the problem and have a call into Kubota. Waiting on a response from them on what to do. This is really pissing me off. I know the issue is the cylinder but the test procedures via the manual say no.
  • Sad
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
Replaced steering cylinder. Still have same issues. And as stated above these issues arise after the hydraulic fluid is heated up for awhile. The dealers gut feeling is the steering valve below the steering wheel which was the first part replaced is defective. Very well could be correct as I'm just scratching my head at this point. I should also mention this noise appeared with the new valve installed and before the new cylinder was. It made the same noise after new cylinder was installed as well so this is why I think his gut feeling is correct. When this noise happens I can feel both the lines going to the cylinder at the valve vibrate.
