Maintenance Schedule “Replace” Items — Stupid..? ?
3,634
My Owners Manual has what I consider pretty stupid Replacement Schedules for some Items.
Example: Oil filer.
It calls for an oil change every 100 hours…. but Oil Filter change only every 200 hours. I.E. every OTHER oil change. Running clean oil thru a dirty filter…. I call that stupid!
It calls for replacing the radiator hoses and clamps, the fuel lines (hoses I presume) , the power steering hoses, …Every TWO Years!
Hell… my tractor is 29 years old with 725 hours, …and they’ve NEVER been changed ….and since they are flexible, dry, and not leaking…. I call That Stupid!
I just changed the coolant last year …and I believe that was the only time in 29 yrs it’s ever been changed…the factory fluid was still clean….and the hoses are flexible and in good condition so I left them alone. I might consider changing them in another 5 yrs when I change the coolant again on MY schedule.
While on that subject of radiator hoses…. Even if I called the dealer and ordered the radiator hoses…. the ones I’ll likely receive will be only a fer years newer….if at all….than the ones I’d be removing. I wonder what the “shelf life” of those things are…. :unsure:
Just for discussion….
Does anybody out there think the factory recommended “replace” schedules make any sense ?? Or do you too agree with me that those items oughta be “on condition“ .
5,134
There was a very short time many years ago I worked in the engineering section of the maintenance department of a reasonably decent size manufacturer. We replaced most routine maintenance items when they got to 75% to 90% of their life expectancy. Replacing piecemeal was inefficient and caused unacceptable downtime. But the scale was such that replacing the overhead lights on one floor of a factory might be 2,000 units and replacing light bulbs 50’ above a factory floor is a bit more of a logistical challenge than swapping a bulb in a desk lamp. There were hundreds of fork trucks, about 5,000 medium and heavy road trucks, etc.
So if I was running a fleet of say 500 tractors mowing roadside right of ways for DOT, I’d probably replace things like belts and hoses on a set schedule of calendar days and/or hours. I run a handful of equipment and vehicles and while downtime isn’t pleasant, it’s not critical. That and all my ICE powered equipment other than the wood splitter resides in climate controlled buildings, quite protected from the elements. So, as you suggest, I inspect the “replace every two years” items, but replace based on condition.
The fan belt on the Farmall is probably older than I am. Admittedly I don’t run it much. If the fan belt ever breaks, I’ll replace it, but not before. If the belts and hoses had been replaced on that thing every two years they would have been replaced 37 times by now, and they’d be due for replacement next year. That would be a bit much IMO.
Hugo Habicht
G1900
Jun 24, 2024
815
1,131
Ireland
Replacing parts as a regular maintenance schedule does make sense when the machine is used constantly and commercially.
For private use it is at every owners discretion what they do, I personally would not change the coolant hoses every two years.
I would agree with you that the time periods for replacing the hoses for example is very short, I would imagine that this is based on marketing rather than engineering decisions.
The oil filter change every second oil change I have seen with a lot of car manufacturers as well, again, I agree with you and I have the feeling (not first hand engineering knowledge) that it does not make sense. I change filters with every oil change, they are cheap and very quick to replace.
p.s.: I do have a set of coolant hoses on the shelf, I have the same concerns about shelf life as you have, but the reasoning here is that the tractors in question are 30-40 years old and at some stage Kubota will stop supplying them. Properly stored (cool, dry, dark) and softened before use I hope they will be fine when I need them.
3,917
There are certain situations where it makes sense to me......aircraft maintenance is one of them for instance.
If my hose "pops" on my tractor, the worst thing is that I have to walk my fat ass home. If a turbine blade lets loose at 50,000 feet, well thats an entirely different scenario.
Obviously, you can't just "pull over" if something goes wrong in some situations.
But "by and large" I see your point, and yes I concur. Ain't no way in hell I am changing hoses every 2 years.
I recently "overhauled" the axles in my truck. Partly because it has nearly 300K on it, and partly because I "sensed" something was wrong.
Turns out, I was 50% right........If I was a Pro Baseball player that would be batting .500.....(I think thats considered good?):unsure:
I agree that some things are just plain "silly' , as you pointed out. (y)
Hugo Habicht
G1900
Jun 24, 2024
815
1,131
Ireland
I think Runs With Scissors brings it to the point: what can happen worst case?
A professional relying on the machine losing potentially thousands of dollars of business when the machine breaks down (in a remote location) will not worry too much about the cost of coolant hoses, reliability is way too important for them. And the Kubota maintenance schedule is based on those users.
My own lawn tractor breaking down? No big deal, apart from the HST making it impossible to tow into the work shop.
3,917
Aside:
Speaking of "turbine blades"........
I "know of a guy" that actually went to prison for lying about the hours on some turbine blades that he sold to someone else.
I don't recall/know the entire story, but......
They ultimately hung him on "mail fraud" because he sent them USPS and had lied about the hours.
Just a crazy story from "back in the day".
5,770
losing an engine at 50,000 is not a big deal. Plenty of time to pick a landing strip while you retrim and do the 'routine'. Just do NOT pick a field full of tall corn or next to a chicken farm.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
644
643
Indiana
My owner's manual states that after the first 50 hours, change the engine oil and filter every 400 hours. I figure that must be a typo.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
798
698
E.
Like any topic we can always pick around the edges and look for the absurd.
For example someone has a 30 yo tractor with 500 hours.... that's a 1/3 of an hour a weeks use so hardly a critical piece of equipment. A toy? A nice to have versus a must have, a hobby? Or maybe a nice to have at best.
If the equipment is commercial and critical I would follow the recommendations set by the engineers. Downtime when the crop has to come off before a rain, or snow needs to be removed before rush hour starts in a few hours and would risk injury or loss of contracts, etc... all make the decisions to take the risks and costs of part failures a very uniqud decision.
For a machine that is a toy then I say go ahead a stretch out maintaince schedules but for guys who rely on uptime I would be very pissed if I heard my family was delaying part replacements until point of failure or past recommendations intervals.
I would be pissed not only for potential loss of downtime, money, and work contracts but even more so for safety reasons if that was in play. Ones health and life and life always trumps saving a few bucks
Personal choice / free will. My choice is almost always follow what the engineers who designed suggest. But free will says do what you want as long as it doesn't put others at risk can be anyone's choice.
pigdoc
G1800S L2500
Aug 19, 2022
336
271
SE Pennsylvania
It's a good idea to write the date and/or the hour-meter reading on every wear-part you install.
-Paul
3,634
Treat ‘em like tires: Store them wrapped (zip-lok bags are good) and away from sunlight and electrical equipment (ozone) and they’ll be good for decades. Same thing with V-belts, gaskets, etc.
The Kubota-dealer’s back-order and price for those M4700 hoses allowed me to keep the installed-ones still in excellent condition. (And NAPA has “universal” types of hoses that can be bent to shape. When I changed the hoses on my 1986 Ferguson compactor/roller I carried the shaped-hoses in to NAPA and got permission to go into the “back room” and compare to all those hanging overhead. I was able to find replacements that had the needed curves and only needed cutting-to-length. It was a lot faster and cheaper than ordering from Ferguson. But some of them hanging back there looked the same age as the ones being replaced.) LOL
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,009
1,388
Pittsburgh
The japanese are known for oil filter changes every other oil change. Two of my three jap bikes have that schedule.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
267
403
NC
Like you, I find a number of things in the recommended maintenance to be crap, but I WILL change the coolant decently often. The anti-corrosion properties are worth the minimal effort. On other vehicles, I've seen a number of head gaskets let go from some small corrosion that crept in from not changing the coolant. I'm not doing a full flush or anything, just draining what comes out and putting new stuff in.
For hoses, I'll just let those go until they need replacement. I recently changed out all the original hoses on a 40-year old Toyota and virtually every hose still was soft and supple and would've gone for many more years with no issues. Granted, that car was garaged it's whole life, but my Kubota has been too...
3,634
I wonder if this isn’t something like when we re-fill the fuel tanks …. allowing existing filters to remain… :unsure:
(But, of course, the filter elements I’m thinking of are visible, inside see-through containers.)
If, when draining the oil, any ”glitter” is seen…. an existing filter Might be in “By-Pass” :eek:
(The Honda CB175 and CB500 bikes I owned back in the ‘70’s had “centrifugal” filters.… small machined rotating assy’s that required opening the cover and scraping the walls of the sort of metallic “sludge” one might find on a magnetized canister-filter.)
8,562
Depending on the state and whether the warehouse/ parts room is climate controlled will determine shelf life of a belt or hose.
If it's not climate controlled and exposed to heat and humidity on a regular basis, they will be toast within 5 years due to dry rot. Especially belts.
One of my suppliers is in Monroe Louisiana.
I had to have a discussion with them about it when a batch of belts i recieved from them started shedding teeth within a month or so of being installed.
Jack@Northeast
LX2610HSDC
May 15, 2021
39
38
Natick, MA
I'm glad I came across this thread. I have a LX2610, 4 years old 275 hrs. I performed 10 hr grease, 50 hr service and yearly oil/filter changes. I exchanged the coolant and fuel filter at 4 years 275 hrs. Everything I changed seems to still be in reasonable condition. After closely reading the manual I was stunned at how many items call for replacement regardless of hours.
I agree with the posts making maintenance decisions based on critical use vs hobby. I'm relieved others feel the same. Happy I don't have to drain a bank account every year.
Very strange Kubota would think the small machines like the LX would be used in critical applications.
JasonW
517
300
Al
All tractors are just tools to complete a task. Regardless of size. “Critical” I’m my mind would be any machine being used to make money or helping take care/feed animals which definitely could be the smaller machines.
IMO the time and hours on the replacement charts are quick but there are a whole slew of people that only follow the owners manual to the T. And that’s for them. Then the others that never open it.
An example would be someone has a fuel issue with their tractor and states they have changed all filters according to the manual. Not realizing they might need to change it again due to fuel contamination. Etc.
Also depends on the climate where the equipment is located and operated. Could be anywhere in the world. Could be used to take the trash can to the end of the road, washed and waxed every month or underground in a salt mine its entire life.
Jack@Northeast
LX2610HSDC
May 15, 2021
39
38
Natick, MA
Fair points. Im the one who usually follows the manual to a "T" as you say. That's why I checked online when I realized I was not keeping up with the maintenance. But you mentioned the schedule is quick. I'm happy to use my best judgement as long as the more experienced agree the schedule is extreme under hobby use. My use is, North East. Light winter snow plowing and loader work of all kinds.
