B8200HST trans questions
rsdata
B8200 HST
Jul 25, 2014
Alexandria, KY
My Kubota is probably 40 years old. I only cut an acre and a half grass on a hill normally for the last 30 years. Runs well until I drained fluid and replaced the hydraulic filter about two months ago. It now appears to act sluggish. I have to push on the forward pedal much harder then I used to to get any speed in mid-range selection. The pedal will not return to center when I release the forward/reverse pedal.
I put this fluid in to replace what was taken out. Any ideas what could be the problem?
TRIAX Agra UTTO XL GL-4 Synthetic Blend Tractor Hydraulic, Transmission, Differential Fluid - All OEM Compatible
10,982
Did you pull and clean the hydraulic screen?
7,202
That sounds like a problem with the pedal not the hydraulic system. Inspect and lubricate the linkages
Hugo Habicht
G1900
Jun 24, 2024
1,540
2,232
Ireland
Is the oil level correct?
Typically after changing it you have to run the tractor and then top it up again. Check on level ground.
rsdata
B8200 HST
Jul 25, 2014
Alexandria, KY
yes I have topped it off, let me re-iterate that after many years of use this hydraulic system worked fine until I decided to do this OVERDUE maintenance item... It still runs but seems sluggish now after the service
7,202
Coincidences do happen.
  1. There is nothing wrong with your choice of oil.
  2. The HST is self contained inside the case so the suction screen for the implement pump is not relevant.
I can not see how a simple oil change would make the trandmission "sluggish" or make the speed control pedal hard to operate. That is a mechanical linkage.
10,982
Wanna rethink your comment? :unsure:
The filter screen has 100% bearing on the HST operation.
It makes the transmission sluggish because it can't get fluid flow.
rsdata
B8200 HST
Jul 25, 2014
Alexandria, KY
Well Wolfman you hit the nail on the head...
finally got around to draining the oil and inspecting the screen.
I did this screen inspect a month ago when I drained and changed the hydraulic oil BUT
holding the screen up to the sun, low and behold the screen was about 90% plugged up
I blew it out with air and brake cleaner, but that only cleaned it to about 50%.
I then scrubbed the screen with mineral spirits and a nylon bristle brush and used compressed air to blow it out... several times.
Close inspection in the sun followed and now I thought about 98% clean... BIG DIFFERENCE from the starting point.
I filtered with an air spray paint screen the old oil going back in. As soon as I started it I could tell it was moving much more crisply and the centering of the front-back power had also returned.
So thanks for the forum members that helped me on my way with my old Kubota.
