6.6M views · 22K reactions | Engine Oil Viscosity Test 😲😲 | Fernandez L. Jayson
Of course there are exceptions like the GM 6.2 where the thin oil has destroyed many engines. GM updated the owners manual and the oil cap to show thicker oil.There's a lot more to it but that's the very basics. Use what the mfg says.
I had only heard of 6.2l issues generically - - no details.Of course there are exceptions like the GM 6.2 where the thin oil has destroyed many engines. GM updated the owners manual and the oil cap to show thicker oil.
that engine will not stay together on any oil. Poorly designed, or should I say it had a decent design but poorly executed. GM knows this. They're trying to shift the liability to the owners. It's what they've done for years and why I do not buy GM vehicles, which is unfortunate because there are things I do like about them, well some of them. It's a matter of principle, that's all.Of course there are exceptions like the GM 6.2 where the thin oil has destroyed many engines. GM updated the owners manual and the oil cap to show thicker oil.
Oil that failed a test of flow at -50F would not have an effect on anything in my use and location!!!!It was quite a few yrs ago on Utube a 'engineer' did a oil test. At the lab they had a freezer that was at some crazy temp like -50* below F.
He had five or six quarts of different brands of oil. Put them in the freezer for a number of hours. Then had a board the clamped each bottle and flipped over to drain the oils. What I remember about the test was the Walmart oil. Even after five minutes not one drop came out of the bottle. Lol
Kind of like trying to get Lucas down a funnel in winter. Gotta mix that thick stuff with some oil to get it all down LOLI had a '68 Ford Fairlane 289 for my first car that was a "fill the oil, check the gas" almost kinda engine, remember the STP oil additive that came in a metal can, that was as thick as molasses? I ended up running about a 50/50 mix in it!
You are missing something but its pretty nuanced.A stupid question: we are dealing mainly with water cooled engines (air cooled engines are a different matter, of course). So the temperature, when running, is regulated by a thermostat.
That means all those different oil viscosities only matter at startup until the engine is heated up. Or am I missing something?
You are missing the fact that the oil pan temperature isn't controlled and that will have some effect.A stupid question: we are dealing mainly with water cooled engines (air cooled engines are a different matter, of course). So the temperature, when running, is regulated by a thermostat.
I should have said clearances rather than tolerances. If you reduce the oil clearance in a journal bearing you get an increase in the oil film pressure. That allows you to use an oil with a lower HTHS.Thank you Dan and lynnmor,
yes, of course the oil temperature is still changing a bit depending on outside temperature.
And modern engines with tighter tolerances I had forgotten; I have only old vehicles![]()
