Instalación tres brazos kubota b6000
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
Hola, quiero instalar los tres brazos en mi Tractor Kubota B6000 pero nunca se le había puesto un cultivador ni ningún accesorio como desbrozadora etc y no tiene nada más que esto que adjunto en la foto. Además de colocar un inversor de giro quiero instalar estos brazos como el tercer punto y los dos inferiores pero no tiene anclaje para poner el eje inferior ni sé cómo va. ¿Que necesito? Estoy un poco perdido.. Gracias
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
I also have a question to see if anyone has experience, I would like to know the tolerance that this type of tractor has when using them on slopes since I am afraid of it tipping over.
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
Hello, I want to install the three arms on my Kubota B6000 tractor, but I've never installed a cultivator or any other attachments like a brush cutter, etc., and it doesn't have anything other than the photo attached. In addition to installing a reverser, I want to install these arms as the third link and the two lower links, but there's no anchor to attach the lower axle, and I don't know how to do it. What do I need? I'm a bit lost. Thanks.
2,428
Looks like you are missing a few pieces that allow the mounting of the arms.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
460
448
Amsterdam, NY
Your tractor did not come with a ROPS (roll over protection system) so you need to be careful.
Going straight up and straight down the slope is the safest way.
If you do not have a front end loader (FEL) then you will need weights for the front to help balance the weight of any attachment on the back. This will keep the front tires from lifting which could cause you to lose the ability to steer. No es bueno!
You could add wheel spacers to the back tires which will widen the stance and help stabilize the tractor. You could also add wheel weights or fill the tires with fluid (not plain water) which will also help. There are many threads on OTT discussing these issues.
3,677
Going “straight up”…a slope …can also result in a “back flip” …
BACKING up a steep slope is safer, of course if that accomplishes the task.
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
The question I'm asking myself is, what slope can it handle? If there are OTT threads that cover this topic, I'd appreciate it if you'd be so kind as to share the link. I'm a little worried; I also don't know what degree of incline my tractor can handle. There are probably people who are much more experienced.
3,677
Some tractor mfr’s suggest 20-25-degrees as the maximum slope for safe operations. (John Deere specifies 20-degrees)
The Problem is: How much equipment does YOUR tractor have ABOVE the axles..?? This addresses the CENTER of GRAVITY of YOUR machine….. and there is no “standard” for measuring that because each machine can be different than all others, even of the same make and model.
There is a discussion on OTT…. (may be many more, but I found this one during a quick-search)…
There is a Related Issue: When Pulling or Towing other objects. It’s important to attach the cable or chain to the object to the “swing arm”…also called the “Drawbar”. .In other words, to the lowest point, preferably below the axle…..NOT the 3-point hitch….as that may result in “flipping” the tractor.
LOADING the tractor onto a trailer …or moving it up a slope under it’s own power …and also ”flip” the tractor. The safest method is to BACK …or REVERSE …the tractor up such a slope.
Hope this helps.
trevoroni
B6000
May 24, 2023
201
251
Here is a photo of the 3 point linkage removed from my B6000.
And another with it installed.
I don't know about the quality but This kit seemed like a cheaper option than trying to find OEM pieces when I was looking at adding it to the other tractor that didn't have it.
It doesn't look like it includes the lower bracket that bolts to the tractor that can be seen in my first photo though. It would not be a hard piece to have made though. I could get some better photos of it if you would like.
Bmyers
May 27, 2019
3,495
4,425
Southern Illinois
OK, I have seen it all now. I will have to go home and tell my wife that Jesus owns a Kubota. I knew it was a good tractor, just didn't realize it was that good. :p
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
Thanks to everyone, I'm much clearer about the third point, and about the plates I need. You're a great help.
Jesús
Kubota B6000
Jul 15, 2025
38
9
Spain
Here is a photo of the 3 point linkage removed from my B6000. View attachment 160183
Would you mind showing me the bottom and top sections so I can see where they're screwed in? Thanks.
Bee-Positive
Nov 16, 2022
460
448
Amsterdam, NY
Geohorn is spot-on about working on slopes, your tractor - your pucker factor - your decision. This is something you'll develop as you get more and more time in the seat. Just the fact that you're thinking about it now instead of after something happens is a good thing.
Below is a picture of MY TRACTOR on a 25 degree slope. I've been going up and down this in 4WD for as long as I've had the BX, no problem. Would I do it going side to side - no way. Where I'm standing taking the picture from the slope is about 15 degrees which I've done side to side, but still makes me nervous so I go up and down. I have nothing but the MMM on, any FEL or rear attachment changes the whole equation.
Be aware if you are going side-to-side, even on very moderately sloped hills turning can flip you without notice especially turning up-hill. More so if you have the front loaded, I've come closer than I like to admit. You've been at it all day, it's getting late and you want to get done, that's when it happens.
Post pictures when you get it all hooked up, we're cheering for you!
Bee-Positive
Nov 16, 2022
460
448
Amsterdam, NY
Two things:
That kit is WAY less expensive than Messick's
Chain driven back blade adjustment, pretty cool.
trevoroni
B6000
May 24, 2023
201
251
I will try and get some better pictures of the plates and where they attach tonight or tomorrow for you.
