Hey, Dummy
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,186
2,846
Near Lancaster, PA, USA
Yep, me. Apparently I can't always tell the difference between yellow and white. My loader is not on the tractor unless I'm using it. Otherwise it's in the shed in front of the tractor. The weather today was nice enough to get out and start some fab work and the loader was part of it. I connected the hoses and moved the joystick to get the loader on. It dumped just fine and the arms rolled into the brackets. However, when I pushed forward on the stick, the loader didn't push down, it lifted. Hmmm. Up was down and down was up. This was a first, but it didn't takes more than a few seconds to figure it out. I backed it out of the shed, shut it down, dropped the bucket and swapped the lines. All is fine now:)
chim
Jan 19, 2013
3,186
2,846
Color code or polarize the connectors
" Apparently I can't always tell the difference between yellow and white"
That's the bad part. They are marked:) In my defense, the shed was a little dark after coming in from the bright sunshine.
hedgerow
456
441
Malcolm NE
As I get older and glasses don't help I find myself turning on the tractor lights more when hooking up in the sheds. I have many cold storage sheds with no power.
7,303
Chim - a while back I mixed up the two connections on my snowblower.
Don’t remember what I screwed up, but I did.
It happens….
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
It could have been worse. I do electrical stuff. 110, 277, 480. I have mixed the wires a couple times on a long day and live to tell.
Only small fires and a big flash for fun.
4,062
I know the “dummy” routine.
I pulled my boat to the marina for service today and realized I forgot to store-away my custom/special trailer hitch-lock. As I hitched-up last nite I laid the lock on the truck rear bumper and made a mental note to store it properly before hauling the boat to the marina service center today.
About half-way to the marina today, I realized I’d forgotten that lock…. got out and checked the rear bumper… nope…not there… so on the return home I scoured the roads looking for it. I back-tracked twice more, spending almost an hour looking for it. No luck.
This evening a friend had a flat on the hiway and called to see if I’d bring him a floor-jack and help him change his tire. (His brand new truck had a flat…. but didn’t have a jack.)
As we finished the tire-change I was putting my floor-jack back in my truck…. and there…..inside the pickup bed…. was my trailer lock. 😳
I‘ve noticed I’m getting distracted/forgetful these days. I left the kitchen stove—top burner ON for the 3rd or 4th time lately drying out a cast-iron skillet after washing it. I left a sink faucet running the other day for several hours and only discovered it by accident.
The doc has checked me for alzheimer's every 6 mos during regular check-ups. He gives me 4 or 5 random words at the beginning of the visit and 15 mins later asks me to repeat them. (one of was analogous… so I deliberately responded “anorchous” LOL
Buffalo
L3901, FEL, mower deck
Mar 17, 2016
102
38
Oklahoma
I would worry about anyone washing a cast-iron skillet with water! The other things, not so much.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
I won't even get into talking about the mistakes I have made. I'm like Northwoods, and I was an industrial electrician like FOREVER! Most of my work was in the 440 v range. When you make a mistake you bloody well know it. 😜🤪😂
4,062
Here’s some “thread-drift” for ya’:
There is considerable differences of opinion out there on how to care for cast-iron.
The most common is “Never use soap/water” to clean it….because it “ruins the seasoning” .
This is an old wives tale….the background of which is rooted in the 18th/19th century …when women and travelers did not have ready-access to water.
Imagine traveling by wagon or cart or foot on the Westward-movement. Water was a prime concern. Stops were hopefully found at stream-crossing where water was available.
Otherwise, the cast-iron pots were scraped-out of food-particles, and cooking-grease or lard was used to prevent rust. This becomes a non-stick coating that became known as “seasoning”.
It wasn’t specifically planned-for as a non-stick surface….That was simply a side-benefit. The reason the pot wasn’t washed was: Water was precious, especially when traveling. (The two barrels on the side of the wagon was water for the harness-animals and people…. and the other was corn or feedstock for them.
Using water for washing was simply not prudent Or possible.… and the concept of “germs” was completely unknown. The act of cooking in that cast iron post had a fortuitous side-benefit as regards germs…. and “soap” was usually “lye”…used primarily for clothing, etc when a stream/river was available.
Modernity has changed all that. But habits and “old sayings” die hard.
”Seasoning” a new skillet is a universal ritual, mostly due to tradition and unfamiliarity with the real reason it was ever the practice. Using a quality fat or oil to “season” new cast-ironware is good.
But there’s simply no good reason to worry about “ruining” cast iron with proper washing using dish detergent and water. (Simply scraping food particles out with a spatula and leaving the pot with grease in it is NOT necessary OR Good for you…. it allows minute food particles to spoil and feed germs… and the ritual lard or animal fat used to prevent rusting will spoil and become Rancid… ruining the taste of newly-cooked food and contributing to the possibility of food poisoning.
Good modern care:
When finished with cast iron, scrape food away, …then use hot water and dish detergent along with a stainless-steel “scrubby” (pot-scrubber) …to scour and clean the cooking surfaces completely. After many months and years of using that metal pot-scrubber….your cast-iron will slowing acquire a very smooth and “slick” surface.
Rinse with hot water thoroughly, then place the cast iron on a stove-top burner …or inside a hot oven…. to thoroughly Dry the iron.
Next, use a few drops of Olive Oil on the cooking-surfaces and spread it thinly with a paper-towel while the pot is still hot, and store it away. Do not worry about the “seasoning”.
Next time you use it…simply wipe it out with a paper-towel… and Enjoy It!
5,088
I will see your "thread drift" and raise you one.
I agree with your analysis of caring for cast iron skillets, with one notable caveat.
I no longer use any sort of "natural vegetable oil" and here is the reason why.
Many moons ago, I was sitting in my chair and this damned little "fruit fly" was bugging the hell out of me. I finally killed it.
Then the next day a few more appeared and were buzzing around. Well this story has played out many times before when the kids were young. Someone has dropped/kicked/forgotten about a grape, or piece of fruit or something and it is decomposing and "creating" these damned little flies.
Well a week goes by and I am spending every waking second looking for this "decomposing fruit".....Talk about a long protracted cursing session.........AGHHHHHHHHHH!!!!!! I am pulling the last remnants of my hair out looking for this "decomposing fruit"
I still can't find it, and the damn flies are EVERY "F'ing" WHERE......
Then I reached for a "iron skillet" and 40 of those damn things flew out of the pan..........
It hit me like a "sack of hammers"......The "olive oil" I was using was the "fruit" that was decomposing.....
I switched to "White Mineral oil" and it never happened again.
(similar story happened to my Sister In Law)
5,088
Lastly, I am of the opinion that the "smooth as glass" feel of the "old school skillet" surfaces is NOT from use.
I believe that to be a "wives tail" as well.
I mean if you think about it, it would take "a thousand centuries" of use to wear down the surface of cast iron...(especially if you are using wooden utensils) ...Not to mention the it would be uneven as hell.
So long ago, I said to myself "to Hell with this!"......
I grabbed my new Lodge cast iron skillet and my trustly 4 inch angle grinder, and made the bottom of it smooth as glass.
Fast Forward 10 years....................
As fate would have it, last Christmas my kids found, and bought me, a "New-Old stock" Griswold skillet.
Guess what?
It is "smooth as a babies ass" directly from the factory. My guess/deduction is the newer ones are just "Chi-Com" knock offs that use inferior casting process's/materials.
And the Griswold is at least 1/2 the weight to boot.
Here is a "side by side" of the Griswold and Lodge. You can see the thickness difference.
6,239
re: cast iron pans..... I used my RO sander and several progressively finer grits to smooooooooth it down . IF you're so inclined you CAN get a mirror finish using 1500, 2000.
4,062
I don’t know about the olive oil you may have used, of course…. but it is well-known (or at least it Should Be) …that some brands of olive oil are counterfeit and contain oils other than from olives.
The various Grades of olive oil are also sometimes mis-labelled as “pure’ or “Virgin” …when in-fact they are not.
I’ve never had a problem with the particular brands I use, but I also do not use unfamiliar brands.
While I‘m not fooled by AI, this google-search reveals: “
Several olive oil brands have been identified as potentially selling fake or adulterated extra virgin olive oil. Some popular brands like Bertolli, Carapelli, Sasso, Mezzetta, Pompeian, Mazola, Colavita, Star, Felippo Berio, Coricelli, Antica Badia, Whole Foods, and Safeway have been named in investigations or studies regarding fake extra virgin olive oil. Additionally, some brands like Naturalia Like a Virgin, La Vie Claire, Cauvin La Bio, Terra Delyssa, Simplemente bon et bio, Bio Village and Carapelli extravergine classico were denounced for marketing olive oil as extra virgin without meeting the required quality standards.
  • Sad
pigdoc
G1800S L2500
Aug 19, 2022
397
337
SE Pennsylvania
A long time ago, I took to attaching a 4-inch length of light chain between the truck's gas cap and filler neck. Reduced size of the Lost Gas Cap line on my balance sheet.
I just leave my car key in the ignition lock.
Crutches.
-Paul
