My L185 has hydraulic fluid coming out of the inspection cover on the right side bellhousing. It's a tear drop shaped metal plate on the right side of the tractor where the engine and transmission meets(photos attached). If I open the inspection plate I see the flywheel. So I assume it's coming from the transmission. What could have gone out to cause the hydraulic fluid to enter the bellhousing? It's does not seem to be under a lot of pressure but a steady flow. Going to split the tractor but just wanted an idea as to what I need to look for. Thank you
