bucket tilt
gleneben
L245DT
Jun 5, 2025
17
oak grove mo.
i have been having issues with bucket tilt , i found out that both tilt cylinder rods are bent. replaced both cylinders and when you pull or push the lever the line to the will pressurize but the bucket wont move. i swapped the lines from the lift cylinders and the bucket works fine and the lift has no response. i want to replace the control but they all have an in and an out port but havent found them with the PB port?
2,060
There is a PB sleeve that is added into the valve port (Tank return or neutral)
rScotty
Kubota M59, JD530, Deere 310SG
Aug 19, 2010
29
11
Colorado Mountains
It sounds like you have one set of lines to the new bucket cylinders reversed so that they are working against each other.
Consider posting some photos of the FEL cyinders and plumbing.
5,267
Your control valve is not the problem. You have a problem with the hydraulic connections.
5,267
i will post pics soon as i can , thanks for the info.
You need to do some simple testing to find the source of the problem.
If the cylinders were opposed they would not work when switched to the boom spool. I think we can rule that out.
