SEAT SWITCH
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
44
29
duluth mn
DOES ANYONE KNOW HOW TO DEACTIVATE THE SEAT SWITCH ON A L3301? SHORT OF PUTTING A CONCRETE BLOVK ON IT?
I HAVE TO STANDUP TO HOOKUP MY FL ATTACHMENTS AND THE ENGINE KEEPS SHUTING OFF.
THANKS FOR ANY INFO/HELP!
dON
CAPT Seabee
Grand L5460
Dec 28, 2022
88
86
Bonners Ferry ID
You can install a bypass rocker switch in an open slot if you have one. Common practice for things like running generators when you have a fixed seat vs. the tilt up. Did one on my L5460 when I put an air ride seat in.
5,179
I simply made a jumper for the switch
DONLI
Jul 28, 2025
44
29
duluth mn
Thank you all for the info will try the jumper.
Don
old and tired
L2800 HST; 2005; R4
Don
Don't know if this is possible but for my L2800, there was enough extra wire going to the OPS, to where I was able to loop the wire over the lever that held down the arm which would allow me to get off the tractor with the PTO running!! (you can stand up and drive forward... doing that). Now if yours is hooked into your seat... this might not work.
pigdoc
G1800S L2500
Aug 19, 2022
336
271
SE Pennsylvania
I simply trimmed about 1/8" of insulation off both wires near the connector and then twisted the connector so that the bare wires were twisted together. Put a drop of silicone sealer on the splice to insulate it.
Obviously, you can do this on either side of the connector.
-Paul
DONLI
Jul 28, 2025
44
29
duluth mn
Did That and it works.
Don
3,933
One might consider it an "ironic twist of fate", but I used a piece of "safety wire" to wire the "safety switch" closed. :unsure:
5,718
not sure what the switch looks like on that model but, here's what I did...
Labman
B2301, 60" finish mower, 60" back blade, 72" disc, 72" cultivator, 3 pt. sprayer
Nov 30, 2021
Kansas
I used a zip tie to keep the switch closed.
nbryan
Jan 3, 2019
1,317
837
Hadashville, Manitoba, Canada
dON
Did you try putting the engine in N, and setting the parking brake? My B2650 allows PTO operation off-the-seat when those conditions are met.
