Front end loader control valve leaking
5,693
Hi all, front loader control valve is leaking, is it usually a simple seal replacement? If so is this a straight forward job? Not sure which loader I have as no numbers visible. Thanks
To me that does not look bad enough to worry sbout. The seals are at the point where the spools exit the body.
Isaidright
L245DT
Jul 31, 2025
Oxford, England
Thanks Dan, that was cleaned up - it’s constantly dripping out over my foot and the floor - so much so that I have to keep topping up the fluid. I guess it will only get worse
5,693
I suggest you determine the model number and lookup the parts breakdown. Seals are not hard but taking detents containing lots of little Jesus!! parts that are under tension apart to get to the seals can be "interesting"
Trash Panda
L2501
Feb 18, 2022
82
62
Wyoming
If you’ve got a hydraulic shop within driving distance, most of them can simply rebuild things like that with parts they have on hand.
It’s worth a shot,
5,693
Thanks, I wish I could determine the make and model. It seems like an unmarked item but will keep looking. Cheers
Kubota online parts shows the L1730 loader in the related units list for a L245.
Does the diagram below look fami⁹liar? Look the subframe over for a serial number data plate. May be up under the tractor and covered by dirt/grease.
