i need help with these errors on my L 3560 tractor
skeeter1981
BX2370
Apr 29, 2025
wisconsin
I'm getting the following engine codes errors P0102 ,P0605, and P0336
the tractor turns over but won't start thanks for any help in advance!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
Found these:
P0102 MAF sensor
P0605 PCM failing its own ROM check
P0336 crankshaft position sensor error
chim
Jan 19, 2013
3,278
2,977
I'm no mechanic and certainly not versed on computerized stuff. According to a few things that popped up the serious concern would be the P0605. The other two may possibly be fixed with cleaning them.
4,213
That crankshaft position sensor is the most serious and will prevent any start….… But the common theme here strikes me as a poor electrical ground somewhere.
11,117
Did the errors pop up after trying to start the tractor with a dead battery?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,174
1,162
E.
I would start with a full electrical check. Battery charged and in condition, grounds, cables, etc...
6,305
this one...
is the 'killer', if it's actually true.
if it's like other computers, it means that during it's 'selftest diagnostic', the program inside of it ( store in ROM) has been corrupted( aka modified). Now that may or not be true but odds are if you replaced the battery 'somehow' that 'fried' the computer. Of course that should not be possible BUT it's been posted here several times it HAS happened.
3,726
2,145
Issue: The engine may fail to start, and DTC code P0605 or P0606 may appear.
Solution: If DTC P0605 is present, replace the engine ECU with the updated engine ECU in the chart below for your unit per the Workshop Manual and complete a manual DPF regeneration per the Diagnosis Manual.
If only DTC P0606 is present, update the ECU Software to the latest software per the chart below for your unit and clear the DTC codes.
Warrenty Terms: 8 Years from retail date (for this specific failure only)
6,305
curious, the ECU ( for the HST version ) is $1500 CDN. Can't believe it's that cheap....
Big questions though...
1) can it be destroyed by simply installing it,then reconnecting battery ?
2) does the dealer have to 'program' anything into it ?
If #2 is true, get the dealer to install it. that way if THEY fry the ECU, THEY have to replace free of charge.
