Identify this part
2,430
That looks sort of like part of a bearing cage (ball separation cage). There is a bearing behind that seal (size 6208?).
The cage is riveted together and (some of) the rivets are highlighted in this picture.
You may be able to get a picture looking in there but I think you have a failed bearing.
on edit: took too long to post!
torch
Jun 10, 2016
2,817
1,059
Muskoka, Ont.
Why did the seal come out?
And to answer the second part of your question (in case it's not obvious) the seal was pushed out by pieces of failed bearing.
torch
Jun 10, 2016
2,817
1,059
Muskoka, Ont.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
209
334
Grayling, MI.
Good luck with the repair. Make sure you find every last piece of that bearing or you'll be looking at a second tear down.
