B7610 stalled with pto engaged, now will not start
Craig T
B7610
Jul 22, 2025
Pulaski County, Missouri
I was mowing up a berm (belly deck) when I high-centered and stalled the motor. Set the PTO back to neutral, clutched it, but when I turned the ignition, nothing but the buzzing of the starter relay under the dash cowl (I tracked the buzzing to that component). Normally, the amber glow plug lamp lights up in the dash when the key is in acc position heading towards start, but not any more. I shifted the PTO selector several times to ensure it was disengaged (even visually verified the switch had no contact) and checked all dozen safety switches with my meter. Still nothing, except for a sketchy positive cable terminal (was only SOLDERED in, so I hydro-crimped it). It's almost like the mid PTO was still engaged and preventing the motor from turning over. I bypassed the solenoid and the starter motor tried to jump but seemed bound up. The machine is VERY difficult to push, as if the hydro drive is still engaged. Is there a way to force the hydro drive to disengage (my other machine had a lever that disengages the hydro to allow easy rolling), or likewise force the PTO to disengage? I suspect the machine still thinks it's mowing and will not allow the motor to turn. Thanks!
8,743
Push the clutch pedal in.
That disengages everything from the motor back.
You can also move the range level to neutral, But the PTO could still be engaged.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,241
157
Coyote Flats,Texas
Welcome to this forum
I suggest to check battery voltage & load test battery. If battery passes test then clean/tighten all four battery cable connections.
5,682
'buzzing pf the starter relay' indicates NOT a 'safety switch' problem.
As TXJim points out,remove all battery cables,clean them very well, reattach, try again.
a 'buzzing' relay indicates insufficent voltage getting to the coil. tries but fails,over and over again.
Craig T
B7610
Jul 22, 2025
I tested the battery and it's good. Also checked and cleaned all four battery cable connections and replaced the positive cable just because I'd found a flaw in it earlier. Issue remains. No help clutching when attempting to start either.
UPDATE: This story finally reached its merry conclusion.
The culprit was the battery. In the garden. With the candlestick.
As others mentioned, there wasn't enough voltage reaching the starter. I was especially suspicious when I tried the headlamps and they barely flickered. "But the battery was only a year-and-a-half old, and showed full on the charger!" But I'd exhausted every other option so I swapped out the battery and threw my portable jumper on it as well. BOOM! It turned over just like that!
The circumstances in which the motor stalled distracted me from the symptoms displayed, so I avoided the obvious cause. I further believe that the battery likely failed to provide amps due to the poor (almost nonexistent) connection between the positive terminal lug and the cable, creating a high-resistance situation that sapped its life prematurely. I'm lucky the solenoid's intact.
Thanks for the assist youse guys!
8,743
If you can't get it to crank when you jump the solenoid you have a serious issue, like the motor being locked up.
3,215
It’s been quite a while since I looked at the starter on either of my tractors, and probably the only one I looked at was the BX 2200 starter, when I installed the interposing relay between the safety contacts and the small terminal on the starter that picks up the starter solenoid.
At the time I remember thinking, or rather wondering, how one would jump the starter and get it to turn the engine over if the solenoid had failed within the starter.
My conclusion was that even using jumper cables to provide a solid 12 V to the power terminal of the starter, would not cause the starter to turn if the internal solenoid failed to operate, or if the starter armature failed in the "open” state.
So I’m puzzled by the comment that if you jump the starter and the engine doesn’t turn over one would have a serious engine issue. My inclination would be to first be suspicious of a starter motor problem…
Perhaps the OP’s B 7610 and my B 2910, are different than my BX?
Since pushing the clutch pedal changes nothing, this certainly does indicate the issue is likely on the engine side of the clutch.
What I am missing?
8,743
What I am missing?
If you bypass the solenoid on the starter the starter will spin but not engage the flywheel.
If you jump the solenoid as I stated it will engage the starter to the flywheel and spin the starter.
This tells you the issue is before the starter solenoid if the motor spins.
If you do this and it engages the solenoid and attempts to turn the starter it could be a bad battery, connections, starter or locked up engine.
If you have eliminated cables, battery, then that leaves starter or motor issue.
You could simply turn the motor by hand to eliminate locked up engine.
3,215
I did miss the point being made about jumping the solenoid...
I get what you are saying, but doing that may require at minimum taking a cover off the starter to expose the solenoid.
Probably easier to make some voltage checks first, like measuring the voltage coming to the starter large lug, and measuring voltage at the small terminal that activates the solenoid (I assume), and is tied to the safety circuit, both while trying to start the engine.
Voltage checks are easy enough to do, and probably faster, if one has a volt meter. Measure both when trying to start the engine, and you end up with very helpful info, pointing one direction or the other...
Jumping the solenoid can be dangerous if one does not understand that the tractor could unexpectantly start and move, if in gear, if done improperly. Granted if the Bendix does not operate, the starter will just spin without engaging the flywheel.
