B7100's have no thermostat and no water pump.This reminds me of a problem I had with a JD 4329 engine I own. A couple years ago it would overheat intermittently at first, but then regularly.
Cleaned the radiator, changed the thermostat, …didn’t fix the problem…..so pulled the thermostat completely….then noticed that when…looking into the radiator-cap-filler-neck…. No water movement was occurring.
Removed the water-pump…and found the impellor was not turning with the shaft…. so the water-pump-pulley being turned by the V-belt performed no actual water-pumping-work.
Replaced the water pump. Problem solved.
Just thought I’d mention an unusual type of failure for folks to add to their repertoire.
Yep…my JD 4239 had reverted to a “thermo-siphon” ….(and also failed to properly cool.)B7100's have no thermostat and no water pump.
ILook real closely and determine where one will fit! The belt on the fan hub powers the dynamo, so you'd have to figure that out also. Keep the screen clean and the radiator fins clean and the engine will run cool.
Because the B7100 only has a low output dynamo.
A good fan will wipe out the battery in nothing flat.
If it's overheating with the mechanical fan you have an issue.
They were designed to run wide open...Thanks for the reply. I do clean the screen and radiator after each use. since there is no tach, I am not sure where to put the throttle when mowing with the belly mower.
I have a 95 Buick Roadmaster. The standard cooling had an electric fans. The performance package had a bigger electric fans. But the HD cooling included in the towing package has a mechanical fan. It would seem GMs engineers agree with you. ;-)the mechanical fan moves a lot more air than most electric fans
a lot of guys in the automotive world swap the mechanical fan for an e-fan because e-fans are supposedly "cool" to have, but in the end they (most of them, almost all aftermarket fans) don't cool nearly as well as the oem installed mechanical fan.
I acquired an old F2400 mower with a property i bought and the previous owner had done that. Probably because he'd also replaced the radiator with one from an old car, the set up he had was never going to work, and the thing would always overheat. I put a more appropriate radiator i found on marketplace on, (still not the right one but how much money do you want to put into a machine like this), and it works fine. I left the electric fan on there, but as everyone else already said the engine driven fan will move far more air than the electric one ever does, so i don't think it contributes much cooling effort.Have anyone installed an electric fan replacing the factory fan to help cool the engine?
