After I posted this I realized I didn't post it in the "Service, Repair & Maintenance" forum. Sorry for the mess up.
I purchased my tractor brand new in '05. The only annoying habit this wonderful tractor ever demanded was with the front left tire.
Every time I would do the pretrip checking the oil and tire pressures the front left would always need to be topped off. Eventually it got worse and the tire would be at "0" psi. Put the air in it up and inspected with no screw or other objects stuck in the tire, nothing. Even the valve stem was tight with no leaks. Using the soapy solution I found the leak to be from the the rim/bead location!
I expected the worse thinking the tire or rim was bad and needed replaced. Pulled the wheel and took it to the tractor dealer explaining my problem.
To him it was no problem and said it was actually common with tractors that had a tire run flat. Well, I've nursed that thing but never run it flat. Anyway, he took it to his tire maching and broke the bead loose and cleaned the bead and inside of the rim real well then filled it back up...no leaks.
Long story short if you have a tire that always leaks down there might be some granuals of dirt in the bead area that need to be cleaned out.
Scott
Scott
