B2650 3pt PTO driven leaf mulcher / vacuum
BlackDog
B2650
Jan 9, 2022
Has anyone used or have experience with a PTO driven leaf vacuum on their Kubota? I see lots of small engine driven models, but I like the thought of the 3pt hitch PTO idea like the Trac Vac Leaf Vac model 854 for my B2650. Any Pros/Cons?
I'd love to find one used - just the 3pt hitch PTO part, no need for the trailer - but have been looking for 2 years on FB Mkt and Craigs with no luck.
5,233
I have one complete with a ragged out ho-made trailer and vacuum hoses. Cheap!!!
5,233
Dan - Great to hear! Can you share any pictures? Is the PTO a branded model or something that you rigged together?
Its an old TracVac.
Apparently the original trailer died so Bubba built one to fit the hood and rear dump door. One of if not the worst welding/fabrication jobs you will ever see complete with two mismatched space saver spares for wheels.
PTO blower/grinder works fine and has a hitch ball for pulling the trailer. I have been toying with the idea of trying to pretty it up a bit.
Here is a picture of the current model - identical as far as I can tell.
BlackDog
B2650
Jan 9, 2022
Love it! That's exactly what I'd like to find. Is the PTO strong enough to have the hose off to the side while you are sucking up leaves or is it only to the mower deck?
5,233
In my case I dont even have a deck. I have a 25' long x 8" dianeter hose with a rigid 4' long pipe on the end that I use to vacuum leaves out of beds, fence lines, and around buildings. Plenty of suction. To do what you want you would need to construct some sort "vacuum head" to run along the side of the tractor. I toyed with that same idea but dropped it when I acquired a G2160 with rear bagger.
