Trying to find drive belt for Kubota Z421 part # K3071-13560
rick sheltra
B7100 4wd diesel w/ Buhler Front end loader
Mar 21, 2012
58
Knoxville, MD
Would anyone know where i could get a drive belt for my Z421 Kubota? They seem to be sold out everywhere. Are the OEM replacement belts ok to use. The prices for genuine items seem to be way off, $125 for a belt. Any advice would be most appreciated.
Thanks Rick
UPDATE 07/21/25
So because of work I still haven't got time to take the deck off and inspect the damage...with any luck it will just be the belt. I added up all the possible parts that could possibly need replacing (the nuts for the spring and tension bar etc) just those few parts were like 40$ So I will just order a belt from Messicks as i know it is broken. So glad I had somewhere to go for advice....
Has anyone ever tried to access that belt by removing the gas tank? probably not a good idea....
So now i just need to locate a diagram for the mower deck as i want to see the belt diagram. I cant find it on that kubota site... sorry to ask so many questions I appreciate the help
5,754
It seems to be a 1/2" x 77" vbeltakak A75A or A75K, so any made with Aramid or Kevlar should be fine. One place has them for $10 US$ !!
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
172
180
$125 for a mower belt? o_Oo_O
That's insane.
John D 2
Jun 6, 2023
172
180
Rick, out of curiosity how long has your oem belt lasted?
My MMM belt is 2 years old and I'm hoping for several more years of use. . .
MOOTS
MX6000
Jun 27, 2019
2,183
2,712
Canton, Georgia
Thanks Rick
K3072-13560 is the superseded part number. Messicks has it. $28.
rick sheltra
Mar 21, 2012
58
Knoxville, MD
I think I bought the mower about 6 years ago. Could be wrong Im getting old like the mower. Only issue so far besides hour meter never working.. Also both kill switches for the seat and brake are intermittent since new. My drive belt is original equipment same with the deck belt. The only thing that really failed was the bearings in the blade mandrels. The ones that came with it and failed in less then a year were chinese in this japanese tractor. Had to get new bearings forgot where they were made but it wasnt china. Other then that it has been great.
I think I am going to remove the deck and check the fan blades as well.
5,556
I'd recommend V Belt guys for all things belts.
I've used them many times. Better belts at much better prices...just sayin'
rick sheltra
Mar 21, 2012
58
Knoxville, MD
3,220
1,646
ebay and just Google search messiks showed it out of stock however another person sent me a messicks link that had 10 of them. They are close to me so Ill get it there gonna check the other parts first
I was asking about the $125.00 price.
rick sheltra
Mar 21, 2012
58
Knoxville, MD
yeah thats what i found on google search..... belts for 24$ to 125$
i just found 12 in stock locally for 30$ at rippeon equip in frederick. so now omw to get it and then tackle this job. looks like the easiest way is to just take the deck off first then change belt .
thanks Rick
thanks gonna check it out now
thanks, these are the best prices you can find. they emailed me and provided 2 belts i needed 6$ for the Kubota and 12$ for a serpentine belt. unbelievable! thanks for the tip
rick sheltra
Mar 21, 2012
58
Knoxville, MD
Hi to all on this hot day in Maryland! So i found a belt got it on with the help of many articles you tube etc. So now i have to put the deck back. So i got the deck mounted and in doing so i seemed to have twisted the mower belt. My question is this: when I put the belt around the rear pulley, should the belt be put on with the V part pointing down or towards the pulley? I just didnt look right when it was the flat side on the rear pulley. Hope it is clear what i am asking Some of the pulleys look like they are for the flat side and others for the v side. Thanks for any info
MOOTS
MX6000
Jun 27, 2019
2,183
2,712
Canton, Georgia
The 3 smaller pullies are the spindles, they get the inside V of belt. Other 3 are idlers, outside of belt. PTO clutch in rear gets inside V.
rick sheltra
Mar 21, 2012
58
Knoxville, MD
WOW thanks for the info. I was looking everywhere but was using tractor model instead of deck model I really appreciate it. OTT has once again saved me from a high bill at the dealer...and i learn something
